Berthos,
The skiffs have the bottom 2/3 of their rigs locked in place by shroud tension, and the top 1/3 is a springy composite tip that automatically bends in the gusts and opens the leech of the main. They need this rapid gust response because they are so tippy. The stability and inertia of a cat to capsize means they dont need such fast response so that the square top mains on Tiapans and many other new cats give adequate dumping of power in gusts.
Whan frank considered wing masts on skiffs, they were way too heavy for such tippy boats even if there were aerodynamic benefits to be found. They also required more adjustment to maximise lift and minimise drag, again something he did not feel could be done in a race with shifting winds.
The higher aspect of say a A class or Tiapan rig is more efficient upwind thean a skiffs rig so if one put a skif rig on a cat it would have to be a similar aspect ratio. Also I think achieving enough rig tension would be almost imposible due to the mast being placed on a beam rather than a hull. ( the skiffs use hugh tension to lock the bottom section of their rig, Mast compression on a 49er is about 1 tonne and on a 18ft skiff it is up to 3 tonnes.
Threre is however a kind of cat, the Laser Vortex (
www.laservortex.org) tunnel hull that uses a skiff style rig to good effect. Unfortunatly no one has put a prebent wingmast on the same hulls so no comparisons can be made.
Regard
Simon
