| HomeTrax wheel hubs?? #61399 11/22/05 09:15 AM 11/22/05 09:15 AM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave OP
Posts: 292 Ontario, Canada | I know there are many who have made their own cat-trax. I am in the middle of this project and have everything I need except....the darn wheel hubs - which I mistakenly thought would be easy to find. I already have some nice, large, lightweight turf tires with the standard four-bolt hub setup. But, I have no hubs. I don`t want to use the big, heavy steel hubs. Though easy to find, steel is overkill, rust-prone and too heavy. I was really hoping to find some plastic hubs with a plastic (delrin) bushing or bearing. I`ve exhausted my options in looking for these to no avail. Can anyone help? Dave | | | Re: HomeTrax wheel hubs??
[Re: Captain_Dave]
#61400 11/22/05 09:50 AM 11/22/05 09:50 AM |
Posts: 306 St. Louis, MO | Just to let you know how the "production" wheels are done. The hubs are nothing more than a rim that has a 4" deep through hole. This hole diameter is about .5" larger than the shaft/axel. Some delrin rods (1/4" dia) are stuck in between the shaft/axel and the ID of the hub to act as bearings. This hub is all Aluminum and so is the shaft/axel. Both are anodize so less prone to corrosion and very light. Basically, the wheel itself is the hub. It's very simple. But, as you noted the trick is to find them somewhere. If you are looking for trailer type stuff try Northern Tool this might be a good place to find some plastic hubs. Good Luck
Nick
Current Boat Looking for one
[Re: hobienick]
#61401 11/22/05 09:52 AM 11/22/05 09:52 AM |
Posts: 306 St. Louis, MO | Now that I think about it, you could make your own hubs to mimmick the set up I described in my last post. All you need is a flange and a short piece of pipe to make that delrin bearing section. You would then attach the wheel to the flange. You may have to do some welding but it could work.
Let me know if what I said makes sense.
Nick
[Re: Captain_Dave]
#61403 11/22/05 10:45 AM 11/22/05 10:45 AM |
Posts: 306 St. Louis, MO | For the delrin rods, go to McMaster-Carr. They are an industrial supplier. You can get the rods in many different diameters. Get the standard length (I think it's 36") and just cut them to the required length. Use Dlerin, it will last longer than Nylon. You may find what you are looking for in here. You can also try MSC I hope this helps,
Nick
[Re: Captain_Dave]
#61405 11/22/05 11:10 AM 11/22/05 11:10 AM |
Posts: 306 St. Louis, MO | They are not tightly packed in, but there are no spacers either. When you pack them as close as you can, there is about a half of a diameter space between two of them.
So, if you have 10 rods for bearings, and you try to jam an 11th one it, the space availabel to do that is only half of what you need.
To make this work, you will need to calculate how many 1/4" or even 3/8" dimeter rods can surround your axel. Just remember to leave an extra .5 diameter so they can roll well.
I assembled mine back in June, so I am going from memory on the sizes.
Nick
[Re: Captain_Dave]
#61407 11/22/05 01:34 PM 11/22/05 01:34 PM |
Posts: 306 St. Louis, MO | Not really. Now that you mention it, the bearings are held in place by a delrin washer that contacts the hub and is backed by a regular SS washer. These are then backed by a cotter pin. This "stack" goes on both sides of the wheels.
The nice part aboutthe Delrin, is it can take a beating from the dirt and still work well.
Nick
[Re: richardinhingham]
#61411 11/23/05 07:47 AM 11/23/05 07:47 AM |
Posts: 306 St. Louis, MO | I was looking at these wheel/tire combos, but they were just too expensive in the quantities (2) I wanted to buy. That's why I just broke down and bought a pair of "production" trax. When figuring in my time and the material cost, it was way cheaper to just buy them. http://www.roleezwheels.com/
Nick
[Re: _flatlander_]
#61413 11/23/05 02:51 PM 11/23/05 02:51 PM |
Posts: 1,187 38.912, -95.37 | For the "Home Trax" (I like that name) with golf cart wheels and tires.
The common golf wheel is the right diameter for a piece of 2 1/2" thin wall electrical conduit, attached to the wheels with a 2 1/2" conduit connector. On the outside of wheels fabricate a flat plate or use a 3 1/2" to 2 1/2" reducing washer for a nice flat surface for the connector locknut. Set the wheel/tire with connectors between the hulls to gauge length of cut 2 1/2" conduit (measure twice, cut once). Slide a 2" schedule 40 PVC conduit inside the 2 1/2" conduit. Pin through the PVC on both ends with bolt, or other method, to hold in place. Here's a rolling chassis ready for cradles clamped to the PVC. We've seen used golfcart wheels and tires from $8 each with rusty wheels and 50% tread. The kid's old outdoor toys seems to be the "hot" source of cradle material.
[Re: _flatlander_]
#61415 11/24/05 10:39 AM 11/24/05 10:39 AM |
Joined: Nov 2005 Posts: 3 Pensacola, FL via Michigan jeeperman
Posts: 3 Pensacola, FL via Michigan | Hello, I just found this forum last week, posted a question, and got an answer pronto. So I think I can return the favor here and offer you guys this idea. I have built some pier fishing carts out of pvc pipe. Being on the gulf coast we want everything to be non-steel. Anyway, I found a source for lawn mower turf tires 13 x 5.00-6 on orange plastic wheels. Not brittle shiney plastic but the dull tuff plastic. They have 3/4" bore flange plastic bushings. Price is good at $12 from Burdens Surplus Center Now for bigger wheels for soft sand here is another alternative to the rollezee tires. ATV front sand tires on aluminum wheels. You can buy brand new pair on alum. wheels for $150 delivered via ebay. They are bald except for the center rib. They make smooth ones too but the are more rare. You can always find 40+ pairs of new and used ones in ebay for less. They are 22" x 8" on 10"dia. rims. Do an ebay search on "sand tire*" or "dune tire*". If you want even more flotation you could get a pair of used rear paddle tires and cut the paddles off to make them smooth.
309
guests, and 86
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
