Small planing cats. #62003
11/29/05 06:26 PM
11/29/05 06:26 PM
Santa Cruz Ca.
chevy43 Offline OP
chevy43  Offline OP
Santa Cruz Ca.
Are there any small planing cats being made?
Somthing like this on a small scale:
http://www.parlier.org/hydraplaneur/evenements/evenements.php?type=record&lang=eng
Re: Small planing cats. [Re: chevy43] #62004
11/29/05 06:47 PM
11/29/05 06:47 PM
South West England
Andy_Lyne Offline
Andy_Lyne  Offline
South West England
Absolutely nothing like the one in the link, but its small and its a planing cat that I built and sail.
From my sailing experiences I think small planing cats have lots of potential. Great fun.
My planing Cat
Andy
Re: Small planing cats. [Re: Andy_Lyne] #62005
11/29/05 07:16 PM
11/29/05 07:16 PM
Bloomington, IN
jbecker Offline
jbecker  Offline
Bloomington, IN
Thanks for link. Interesting craft you've created. So how about telling us a little about your experience sailing it? How does it handle? How much wind does it take to get it up on plane? etc., etc.
Jeff
Tiger 849
Re: Small planing cats. [Re: Andy_Lyne] #62006
11/29/05 07:20 PM
11/29/05 07:20 PM
Santa Cruz Ca.
chevy43 Offline OP
chevy43  Offline OP
Santa Cruz Ca.
That is pretty darn cool Andy! Nice job.
One could even buy a couple of larger used sailboards and mount a tramp between them.
I'm just amazed that no one is building a planing production cat though.
Re: Small planing cats. [Re: chevy43] #62007
11/30/05 03:59 AM
11/30/05 03:59 AM
South West England
Andy_Lyne Offline
Andy_Lyne  Offline
South West England
Thanks for the positive comments.
It gets up on the plane quite early. It will never be quick round a course due to the fact I only have a single rudder for minimal resistance, therefore has a fair bit of leaway when going into wind, but for blasting up and down on a reach it's a hoot!
See the link below for a fuller story
Planing Cat
Andy
Re: Small planing cats. [Re: Andy_Lyne] #62008
11/30/05 04:51 AM
11/30/05 04:51 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
The Paper Tiger is a boat sailed in Australia and New Zealand, not sure of the numbers still sailing, we had a good large fleet in South Africa but it just died out in the 90`s. A great 14ft single-handed boat, you could build it in plywood easily, weighed nothing and went like stink, I remember watching the PT sailors surfing waves passing Hobie 16`s down massive waves offshore Durban (I was on one of the Hobies being passed.) They definitely plane downwind, and sail on the chines well upwind.
Had one for a while, but moved on when the class died.
What a great little boat.
web page
Re: Small planing cats. [Re: Steve_Kwiksilver] #62009
12/01/05 01:27 AM
12/01/05 01:27 AM
Darryl_Barrett Offline
There are still good fleets of Paper Tigers racing in Australia and New Zealand.
Re: Small planing cats. [Re: Darryl_Barrett] #62010
12/01/05 12:01 PM
12/01/05 12:01 PM
NC
calcheck Offline
calcheck  Offline
NC
What about adding a small skeg so it doesn't slip so much- a kickup windsurfer daggerboard- I think someone might have said that - or a small strip rinning down the middle of the hull to take the brunt of beaching wear and tear and it might make take pressure off the tiller. Or are you just going to leave it as is?
John R.
Re: Small planing cats. [Re: calcheck] #62011
12/01/05 05:46 PM
12/01/05 05:46 PM
South West England
Andy_Lyne Offline
Andy_Lyne  Offline
South West England
Hi John
A long skeg may well be the answer.
However, I have stopped developing my cat as I am in the process of building my next contraption....I reckon I have found quite a fast hull shape so am making a much lighter monohull using the same hull shape but with hiking racks. I'll be experimenting with amas on each side to add a bit of stability. All up weight is on target for 35Kg using an 8 - 9 metre windsurfer rig and 16 guage alloy tubing for the racks.
Apologies for mentioning the word monohull on this great forum.
Andy
Re: Small planing cats. [Re: Andy_Lyne] #62012
12/01/05 05:55 PM
12/01/05 05:55 PM
BLAS-FEMUR!
Re: Small planing cats. [Re: MauganN20] #62013
12/02/05 11:46 AM
12/02/05 11:46 AM
Burn her!
Re: Small planing cats. [Re: MauganN20] #62014
08/01/06 10:35 PM
08/01/06 10:35 PM
G
GregOrca Offline
GregOrca  Offline
G
Hi folks.
Check out this video of a planing production catamaran from 1980. It performs well here in 15 knots of wind despite a poorly cut sail. www.mckeewildthings.com/video/itzacatbig.mov
you will need the latest version of quicktime.It's 40mb
There is a smaller 15mb version at www.mckeewildthings.com/video/itzacatsml.mov
The hull widths and planforms were chosen based on calculations of planing efficiency, not because they resemble a sailboard. Note than the hulls are canted at an angle to each other so that the leeward hull is at an effective planing angle when the windward hull is slightly lifted from the water. A later version was scaled up to 17 feet long and had two steps to reduce wetted surface, so that it's wetted surface when planing was much less than the craft in the video, but with a tornado sized rig.
Re: Small planing cats. [Re: GregOrca] #62015
08/01/06 11:14 PM
08/01/06 11:14 PM
For the record (and despite popular belief) the steps in planing hulls are not there to reduce wetted surface. They actually increase the lift available by increasing the amount of hull that is "planing". This is not the time or place for a hydrodynamics lecture so you'll have to trust me on this.
Re: Small planing cats. [Re: ] #62016
08/01/06 11:44 PM
08/01/06 11:44 PM
G
GregOrca Offline
GregOrca  Offline
G
Hi scarecrow. No need to have to trust you. You are correct that steps increase available planing lift. Having been a codesigner of the boat in the video and having built step hull cats, sailboards, water skis and speed boats as well as full size robotic whales and sharks I'm quite familiar with fluid dynamics. However steps can effectively reduce wetted surface area with an appropriate design, and as the boat speed increases, wetted surface is substantially reduced compared to a comparable length non-stepped planing hull. More planing lift yet less boat in the water.
Re: Small planing cats. [Re: GregOrca] #62017
08/02/06 05:34 AM
08/02/06 05:34 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
The hydroplane [speedboat with sponsons forward] would have to be the epitome of this concept, yes?
Re: Small planing cats. [Re: Berny] #62018
08/02/06 07:10 AM
08/02/06 07:10 AM
Or airplane floats - consideration has to be given to various angles of attack and low drag at various speeds.
Re: Small planing cats. [Re: GregOrca] #62019
08/02/06 03:34 PM
08/02/06 03:34 PM
I couldn't agree more. I was probably over simplifying as a lot of people seem to think that the saving is in the hull area immediately aft of the step, rather than in the topsides etc.
0 registered members (), 487 guests, and 34 spiders.
