Page 2 of 3 1 2 3
Re: Sails, Wings, and Winglets [Re: hobiegary] #65383
01/25/06 02:02 PM
01/25/06 02:02 PM
Panama City Beach, FL
steveh Offline
steveh  Offline
Gary, could you please post the link in the tinyurl link? For whatever reason, I can't get tinyurls.
Re: Sails, Wings, and Winglets [Re: Rolf_Nilsen] #65384
01/25/06 04:39 PM
01/25/06 04:39 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Connor & co did not know anything about the boat the kiwis already had buildt in secret, before they challenged, except the length and width (and boy, was the kiwi boat wide!). The kiwis was obviously thinking "outside the box", and to catch up they needed something really spectacular.
I was in Auckland just after Conner lost the Cup to the Kiwis. I was walking around the port area and saw both Black Magic and the humungous challenger on the hard. The failed challenge boat made Black Magic look like a Sabot.
They were both close to the YC where the Cup was kept. I looked in the front door and it was sitting in a case just inside. That didn't last long because some nutter took a hammer to it.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Sails, Wings, and Winglets [Re: Mary] #65385
01/25/06 07:32 PM
01/25/06 07:32 PM
catman Offline
catman  Offline
I am told the soft-sail Stars & Stripes is in Florida, currently owned by somebody in the Tampa/St. Pete area. I have notes about this and the name of the owner in one of my notebooks, but can't find it right now.
When I was looking for the pic I read something about it being in Key West availible for charter. I didn't pay attention to date so that may have been a while ago. That would be the soft sail version.
Re: Sails, Wings, and Winglets [Re: steveh] #65386
01/25/06 07:40 PM
01/25/06 07:40 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Santa Monica Bay
Re: Sails, Wings, and Winglets [Re: scooby_simon] #65387
01/25/06 08:04 PM
01/25/06 08:04 PM
catman Offline
catman  Offline
Shame it was not the same shape or even anything like the boat that was challenged in.
It did turn the AC in to what it is now, so I suppose it was progress. [/quote]
Fay (I think that was his name) got what he deserved.
Re: Sails, Wings, and Winglets [Re: catman] #65388
01/25/06 11:19 PM
01/25/06 11:19 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
1. Perhaps a mast-top winglet system would actually work in wave-piercing cats like A-class cats: Since pitching is not helpful to this concept, the wave-piercers seem to do it less.
2. Has anyone actually tried measuring pitching in wave piercers vs lets say- Marstrom conventional hull shapes?
This could be done from a digital video tape or a CD: at 1 second intervals, measure angle of mast rake for each boat. They should be sailing parallel to another to weather in appreciable waves for several minutes.
Put data on Excel sheet, (or by some magic maths which I do not possess)---determine which pitches less, and how much less!
Dacarls:
Re: Sails, Wings, and Winglets [Re: dacarls] #65389
01/26/06 02:01 AM
01/26/06 02:01 AM
Tornado_ALIVE Offline
SS soft sail and wing together
Re: Sails, Wings, and Winglets [Re: Tornado_ALIVE] #65390
01/26/06 02:08 AM
01/26/06 02:08 AM
SnS soft sail
Re: Sails, Wings, and Winglets [Re: Tornado_ALIVE] #65391
01/26/06 02:12 AM
01/26/06 02:12 AM
SnS wing sail as it sits today...... I downloaded these pics from an advertisement advertising it for sail..... Cannot remeber the site now.
Boat was used for chartered crusies and the boat is very run down..... The wing is riddled with spiders on the inside.
Re: Sails, Wings, and Winglets [Re: Tornado_ALIVE] #65392
01/26/06 02:14 AM
01/26/06 02:14 AM
2nd
Re: Sails, Wings, and Winglets [Re: Tornado_ALIVE] #65393
01/26/06 02:15 AM
01/26/06 02:15 AM
3rd
Re: Sails, Wings, and Winglets [Re: Tornado_ALIVE] #65394
01/26/06 10:29 AM
01/26/06 10:29 AM
can't imagine that its too good for the boat to sit there with the hard wing up.
Imagine if a squall came down through there from the wrong direction... ouch!
Re: Sails, Wings, and Winglets [Re: Inter_Michael] #65395
01/26/06 10:41 AM
01/26/06 10:41 AM
Nimrod Offline
Nimrod  Offline
Winglets are vertical extensions of wingtips that improve an aircraft's fuel efficiency and cruising range. Designed as small airfoils, winglets reduce the aerodynamic drag associated with vortices that develop at the wingtips as the airplane moves through the air. By reducing wingtip drag, fuel consumption goes down and range is extended.
Aircraft of all types and sizes are flying with winglets -- from single-seat hang gliders and ultralights to global jumbo jets. Some aircraft are designed and manufactured with sleek upturned winglets that blend smoothly into the outer wing sections. Add-on winglets are also custom made for many types of aircraft.
Since the 1970s, when the price of aviation fuel began spiraling upward, airlines and aircraft manufacturers have looked at many ways to improve the operating efficiency of their aircraft. Winglets have become one of the industry's most visible fuel-saving technologies and their use continues to expand.
Winglets increase an aircraft's operating efficiency by reducing what is called induced drag at the tips of the wings. An aircraft's wing is shaped to generate negative pressure on the upper surface and positive pressure on the lower surface as the aircraft moves forward. This unequal pressure creates lift across the upper surface and the aircraft is able to leave the ground and fly.
Unequal pressure, however, also causes air at each wingtip to flow outward along the lower surface, around the tip, and inboard along the upper surface producing a whirlwind of air called a wingtip vortex. The effect of these vortices is increased drag and reduced lift that results in less flight efficiency and higher fuel costs.
Winglets, which are airfoils operating just like a sailboat tacking upwind, produce a forward thrust inside the circulation field of the vortices and reduce their strength. Weaker vortices mean less drag at the wingtips and lift is restored. Improved wing efficiency translates to more payload, reduced fuel consumption, and a longer cruising range that can allow an air carrier to expand routes and destinations.
To produce as much forward thrust as possible, the winglet's airfoil is designed with the same attention as the airfoil of the wings themselves. Performance improvements generated by winglets, however, depend on factors such as the basic design of the aircraft, engine efficiency, and even the weather in which an aircraft is operating.
The shapes and sizes of winglets, and the angles at which they are mounted with respect to the main wings, differ between the many types and sizes of aircraft produced but they all represent improved efficiency. Throughout the aviation industry, winglets are responsible for increased mileage rates of as much as 7%.
Aircraft manufacturers and makers of add-on winglets have also reported improved cruising speeds, time-to-climb rates, and higher operating altitudes.
The use of winglets throughout the aviation industry in the U.S. and overseas is constantly growing. Winglets now appear on powerless hang gliders soaring above mountain ridges and from seaside cliffs. Sailplane builders around the world have included blended winglets to their designs and the sleek, graceful gliders are silently soaring farther than ever Corporate-size Learjet's were the first commercial aircraft to use winglets. Now, several decades later, winglets are incorporated into the designs of many other business jets such as Gulfstreams and the Global Express: a new aircraft built by Lear's parent company, Bombardier.
Retrofitting winglets to existing business jets is also a fast-growing market within the aviation industry itself. Many winglet marketing firms report their products help increase aircraft roll rates and lower approach and takeoff speeds.
Winglets are now quite common on large jetliners and many tower as high as six feet. The first big jetliner to carry the innovation into the air was the MD-11, originally designed and built by McDonnell-Douglas and now part of the Boeing aerospace family. Other Boeing aircraft flying with winglets are the 747-400F, the version currently being built, Boeing BBJ business jets which are custom-built 737s, and the C-17 military transport. Boeing is also offering winglet options on new advanced models of the 737 series of passenger jets.
Most prominent foreign carrier of winglets are the many models of the 300 series of jetliners designed and built by Airbus Industries. The future A380 Airbus, a huge intercontinental double-deck jetliner now under development, will also utilize winglet technology.
The first homebuilts with winglets on the general aviation market were the Vari-Eze and Long-Eze models designed by Burt Rutan, a pioneer in aircraft design innovations. Now, the majority of homebuilt aircraft coming out of shops, garages, and hangars around the world display winglets of varying shapes and sizes.
Re: Sails, Wings, and Winglets [Re: calcheck] #65396
01/26/06 10:44 AM
01/26/06 10:44 AM
I had an e-mail discussion a while back with Dave Ellis. I had asked him his opinion about the possibility of masthead floats being designed so they actually give lift, and the possibilities of having fixed or articulating masthead winglets (which he refers to as end plates). Here is one of his responses, and I found it very interesting:
Horizontal airfoils. I like it.
In the late 60s the A-cats and C's at Cabrillo Beach YC, Long Beach, CA, used "end plate" booms. Some used a wishbone down low with Dacron filling it in. Others used a normal, for the day, boom with Ocumme ply wings. We made sure that it was very slightly HIGHER at the clew. This was not to lift the boat, but to compress the air and make the air lift. If the Park Avenue Boom thing angled down, we felt it would blanket part of the bottom of the sail.
The old Suicide class (ask Bill Roberts) was anything-goes in monohull, but with only 125 square feet of actual sail area, including mast. It became very efficient, using an A-cat style mast and wishbone main, 1950's and 60's materials, of course. Tried was an end plate on the top of the mast. Again, it was more for reducing tip vortex than lift, although it was angled up on the front for the same reason the boom was angled down on the tack. The class ruled that they had to count the tip deflector as sail area, so it was quickly abandoned.(Most booms on dinghies are faster with the boom lower at the clew, It makes for leading edge foot, instead of trailing with its tip vortex and loss of pressure under the boom.)
On the Suicide, wind resistance on the spars and hull was a major design consideration. Many of the hulls looked like missiles or long cigars to try to cut the wind. It helped.
I'm no scientist. I do teach racing for Offshore and North U so have lots of feedback from clients. I think a wing would work IF it were not counted sail area.
In windsurfing, the sailor can re-align the sail to near-horizontal and catch air to a remarkable degree. But it also slows the board so that when it floats to the water it is barely moving ahead. If he had two sails, one to go and one to lift, hmmm. Kites are the obvious answer. I'm trying to figure out how to control it alone while sailing single-handed.
Of course, a well-designed asymmetrical chute lifts our bows. Most of the time.
I have built a Formula 14 as a test-bed. I really don't care about a Portsmouth # for it. Hydrofoils will be later. I want to try it the way it is first.
But you have made me think about a wing at the top of the mast that I can also use to keep the windsurfing sail from de-powering as fast by tiny blocks and lines leading down ala C-cat wing masts to keep the fathead leach from falling off so much. The top-mast wing would help the tip vortex thing and maybe lift the boat a bit. Kites do. Or maybe the drag would negate any advantage.
We who care not about design rules get to experiment and spend our time and money!
Dave Ellis
Re: Sails, Wings, and Winglets [Re: Inter_Michael] #65397
01/26/06 03:37 PM
01/26/06 03:37 PM
California!
Inter_Michael Offline OP
California!
Thank you very much for all the info. Great stuff. I like the idea of using something more 'aerodynamic' than the traditional hobie bob 'football' at the masthead.
Michael
Re: Sails, Wings, and Winglets [Re: Inter_Michael] #65398
01/27/06 07:10 PM
01/27/06 07:10 PM
WEST. MICH. USA
DVL Offline
DVL  Offline
WEST. MICH. USA
Not only for airplanes. Big butt Fans has added wing tip vortex's to the large overhead fans used in industry to cool factories. These fans operate at lower speeds, generate more air flow. Apparently the engineers have tested with software, wind tunnels, and independent testing.
www.BigAssFans.com
Re: Sails, Wings, and Winglets [Re: DVL] #65399
01/30/06 11:35 PM
01/30/06 11:35 PM
paul57man Offline
paul57man  Offline
I have used endplates on my RC boat they seem to greatly improve the sail's power, even if the head is twisting off a bit. I even made up a big carbon one (650mm) for my taipan but have never got a chance to rig it up yet.
Re: Sails, Wings, and Winglets [Re: paul57man] #65400
01/31/06 04:25 AM
01/31/06 04:25 AM
Picture please?
Re: Sails, Wings, and Winglets [Re: Inter_Michael] #65401
01/31/06 10:56 AM
01/31/06 10:56 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
The concept of an automatic inflation chicken float attached to a square top main and shaped as a winglet has been discussed a couple of years ago in this forum.
The idea was to improve safety and the challenge remains the same: how to maintain or improve performance through the winglet shape, given the losses due to more weight in a bad place (high).
If my memory doesn't fail, the chosen inflation system was a paintball gas cartridge and the winglet-float would be attached to the sail instead of the mast to facilitate maintenance.
Luiz
Luiz
Re: Sails, Wings, and Winglets [Re: Luiz] #65402
02/01/06 09:13 AM
02/01/06 09:13 AM
This is why the genoas on racing mono hulls are so annoyingly low. The deck acts like a winglet to separate the pressures until the trailing edge.
Matt
Page 2 of 3 1 2 3
0 registered members (), 484 guests, and 33 spiders.
