Page 2 of 7 1 2 3 4 5 6 7
Re: Beginner boat???? [Re: Jake] #70514
03/28/06 03:13 PM
03/28/06 03:13 PM
It comes from my memory of the Hobie literature over a twenty some year period.
If you question those numbers, please state your case. And remember we're trying to advise a beginning sailor who states a weight of 128 lbs.
What you can do may be outside someone elses ability.
Re: Beginner boat???? [Re: fin.] #70515
03/28/06 03:16 PM
03/28/06 03:16 PM
OK...no wind, no waves - 185lbs to right sounds about right. But how did you capsize it to begin with if there was no wind? Remember that there is a technique to righting a catamaran so that you use the wind to your mechanical advantage. Make certain the mast is water tight because if it fills it could become unlikely that the boat could be righted at all. A little preparation and you won't have to worry about it.
There are nylon bags that you can keep on board that have a small block and tackle system so that you can 1) attach it to the boat, 2) lower it in the water (and fill it) and 3) hoist it to give you additional righting leverage. There are also righting poles (which are much easier to operate) and obviously outside assistance if you are sailing with other sailboats (double handed so one person can leave the other boat).
Re: Beginner boat???? [Re: fin.] #70516
03/28/06 03:19 PM
03/28/06 03:19 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
With no wind and no waves it's a challenge to right a 16 with 260lbs. That is the minimum selected for womens racing based somewhat on the ability to right the boat. With wind it is much easier. Sunny, Get a spare life jacket and harness and invite people out.
Attached: A couple of 120lb women that can make the cat fly.
Pat Bisesi Fleet 204
Re: Beginner boat???? [Re: Jake] #70517
03/28/06 03:27 PM
03/28/06 03:27 PM
With a line from the top of the mast and the help of several friends. At one time, it was a fairly common training drill. The trick is keep one hull stationary. Not as easy as it sounds.
Re: Beginner boat???? [Re: fin.] #70518
03/28/06 03:51 PM
03/28/06 03:51 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
One of the races we'd do at fun sails was a tip & tie. Basically, start and somewhere on the course tip the boat over, tie a balloon to the top of the mast, right the boat, and finish. With two people swinging out on the traps they were easy to tip.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Beginner boat???? [Re: fin.] #70519
03/28/06 04:00 PM
03/28/06 04:00 PM
California
mmiller Offline
mmiller  Offline
California
From my personal experience...
I have sailed at minimum carrying weight to get to (285). I WAS racing at about 275 combined. I could get the 16 or 18 up with that, but would use the crew on my shoulders to make it easier / quicker. Especially on the 18.
In no wind... it is harder, not easier to right. You need a breeze to get under the sails and add a bit of lift. With a breeze you can right with less weight.
If you are light, you can carry a "Righting Bucket" or canvas bag to fill with water. This is slung over your shoulder for more righting weight. These bags can carry about 150 lbs. of water.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Beginner boat???? [Re: hobie1616] #70520
03/28/06 04:01 PM
03/28/06 04:01 PM
Sunny:
This is a little off the subject, but if you get a TheMightyHobie18 you can do what these guys are doing. Series 2.
http://www.torsten-hengstmann.de/segeln/download/videos.htm
Re: Beginner boat???? [Re: fin.] #70521
03/28/06 04:41 PM
03/28/06 04:41 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
Hey Jake, Find a H16 and get up to the Madcatter. It would be very interesting to get your take on racing the boat compared to the F18 fleet.
Lots of pretty boats on the beach at Oneida Lake
Re: Beginner boat???? [Re: fin.] #70522
03/28/06 04:41 PM
03/28/06 04:41 PM
Pete:
I did that in 1980 off the coast of Freeport Texas in 14 foot rollers. It was a HOOT and scary. All you could see was the top 3-4 feet of the competitors mast. Had to really watch you didn't hit someone. We were weightless for a second or two. Real rush.
Doug Snell
Hobie 17
www.tcdyc.com
Re: Beginner boat???? [Re: hobie1616] #70523
03/28/06 07:38 PM
03/28/06 07:38 PM
Upstate, South Carolina
SunnyZ Offline OP
SunnyZ  Offline OP
Gentlemen, thank you so much for the information. I really respect your opinions. It looks like most agree that the H16 would be something for me to consider seriously.
I am sure David, Jake or Cary Palmer will help me find something reasonable for my money.
Doug,
Thanks for the book suggestion. I will get one. I appreciate all the help I can get.
Re: Beginner boat???? [Re: SunnyZ] #70524
03/28/06 08:42 PM
03/28/06 08:42 PM
Sunny:
Way back when, the "Bible" for racing the H16, was "Welcome to A Fleet" by Jack Sammons. If you can get hold of a copy, I'm sure much is still valid.
Re: Beginner boat???? [Re: SunnyZ] #70525
03/28/06 08:48 PM
03/28/06 08:48 PM
Sunny:
Your welcome. Get the magazine.
http://store.catsailor.com/tek9.asp?pg=products&specific=jrnnksdrq
The Drills book is good too if you can get the guys to work with you and set marks. http://store.catsailor.com/tek9.asp?pg=products&specific=jqcmjmrpm
There is a whole chapter in Rick's book on Hobie 16 setup.
You may also want to get this
http://store.catsailor.com/tek9.asp?pg=products&specific=jrorgnjse
It is by Phil Berman.
Main thing is read and practice, read and practice. BUT nothing will beat time on the water. Let use know when you get it and let us see some photos. send me a email link and I will send you H17 and Ashleigh's Nacra 4.5 when we get it. Think I am going to put a Hooter on it.
Doug Snell
Hobie 17
www.tcdyc.com
dsnell4 at houston dot rr dot com
Re: Beginner boat???? [Re: SunnyZ] #70526
03/28/06 08:57 PM
03/28/06 08:57 PM
Ohio
Jamie Diamond Offline
Ohio
Wendy, you should check out Spring Fever on Easter Weekend, Lake Hartwell GA. They will have a good selection of boats including 3 little person boats. Hobie 14, F14 which is usually a souped up Hobie 14, and Mystere 4.3. Another boat you might think about at your side is a decent used A cat.
http://www.twinhulls.com/springfever2006/06attendees/
Re: Beginner boat???? [Re: ] #70527
03/28/06 09:31 PM
03/28/06 09:31 PM
SunnyZ Offline OP
SunnyZ  Offline OP
Doug Snell
Hobie 17
Thanks for the links. I will look at everything. I would love to see pictures of Ashleigh's boat. I will keep you updated too.
...um...what's a hooter?
Re: Beginner boat???? [Re: Jamie Diamond] #70528
03/28/06 09:39 PM
03/28/06 09:39 PM
SunnyZ Offline OP
SunnyZ  Offline OP
I wish I could. Mama's comin' down that weekend. What's the next one?
Re: Beginner boat???? [Re: SunnyZ] #70529
03/28/06 09:45 PM
03/28/06 09:45 PM
Wendy:
It is a roller furling spinnaker.
http://store.catsailor.com/tek9.asp?pg=products&specific=jmnrkomnk0
I may just do a homemade system with a windsurfer mast if it is cheaper. Send me a email link.
Doug Snell
Hobie 17
www.tcdyc.com
Re: Beginner boat???? [Re: SunnyZ] #70530
03/28/06 10:17 PM
03/28/06 10:17 PM
SunnyZ Offline OP
SunnyZ  Offline OP
Okay,
Several of you have told me to try out different boats before I buy one.(I am laughing as I write this)This poses a problem for me since I am getting a boat to LEARN on...
LOL, LOL Exactly what am I supposed to try to do with these perspective purchases? Ha Ha Ha...
So far the extent of my experience is that I can follow direction on one. If the directions are simple enough.
I am a NOVICE. But...I will work hard. I am not afraid to look or sound silly in order to learn something. There is not much I am afraid enough of not to do it anyway. I don't give up. (tenacious is an understatement) And there are very few things I have thought were as fun as this is.
So did your opinion of a beginner boat for me change?
Re: Beginner boat???? [Re: SunnyZ] #70531
03/28/06 10:25 PM
03/28/06 10:25 PM
Before you buy an H16 (or any other boat), I would like you to:
1. Get it off the trailer
2. Step the mast
3. Get it onto the beach dolly.
You weigh 128 lbs, this boat weighs over 300!
Re: Beginner boat???? [Re: fin.] #70532
03/28/06 10:27 PM
03/28/06 10:27 PM
SunnyZ Offline OP
SunnyZ  Offline OP
Sound advice well taken
Re: Beginner boat???? [Re: SunnyZ] #70533
03/28/06 10:53 PM
03/28/06 10:53 PM
hobie1616 Offline
hobie1616  Offline
I am a NOVICE.
Don’t worry about that, we all were once.
You’ll do fine. Ask dumb questions (there really are no dumb questions), watch other sailors and boats and get out and sail!!
Oh yeah. We’ll expect to see you competing as a skipper in a national event within three years.
0 registered members (), 203 guests, and 72 spiders.
