| Re: Frame/Hull flex how muck is OK ? ?
[Re: Captain_Dave]
#72297 04/10/06 10:47 AM 04/10/06 10:47 AM |
Posts: 306 St. Louis, MO | There are a couple of ways to take care of this problem. 5" isn't that bad. First, the motion of the pylons in the castings. You will hear people tell you to epoxy them into the castings. This will give you a great custom fit between the casting and pylon. I don't like this idea as it makes removal more difficult. I like making shims from old soda cans to insert into the gaps. This allows easy removal and adjustment.
Second, tramp tension. This will help tighten up your entire boat. The tramp adds rigidity to the frame like a gusset in a 90 deg joint. There are posts on this site and the hobie site abotu using your main blocks to get some prebend in the frame.
I think you will notice an improvement with just tightening the tramp. Doing the shim/epoxy to the pylon casting joint will help reduce wear caused by the parts moveing against each other.
Nick
Current Boat Looking for one
[Re: Captain_Dave]
#72299 04/10/06 11:26 AM 04/10/06 11:26 AM |
Posts: 306 St. Louis, MO | I've actually never seen a new H16 so I have no idea. Matt Miller will be able to tell you.
I've seen some boats with as much as 13" of flex. It was awful. tightening the tramp took care of most of it.
Nick
265
guests, and 85
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
