In need of some h16 parts #77997
06/20/06 07:29 AM
06/20/06 07:29 AM
I
Ian Offline OP
Ian  Offline OP
I
Hi my name is Ian i live just west of chicago, il and am in need of some h16 parts as the title says. I need a h16 mast mostly (have a crack at the bottom from the first winter i had it <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> ) and could use 2 jib blocks.. I have not found anyone selling masts in the chicago area online anyways so any help would be appreciated, willing to travel to pick it up within reason.. Thanks All
Re: In need of some h16 parts [Re: Ian] #77998
06/20/06 07:58 AM
06/20/06 07:58 AM
Commerce Twp, MI
tigerboy Offline
tigerboy  Offline
Commerce Twp, MI
Ian,
Check with Hedlund Marine. They are the Chicago area Hobie dealer. Their phone number is 847-251-0515 and the address is 515 Green Bay Road, Wilmette, IL 60091. They are located about 25 minutes north of downtown Chicago. Good luck in your quest.
Tiger Sailor
Re: In need of some h16 parts [Re: Ian] #77999
06/20/06 08:10 AM
06/20/06 08:10 AM
Chicago, IL
Krisu13 Offline
Krisu13  Offline
Chicago, IL
Try ebay. You can find everything you need. It just might take some time.
Kris
I20
Re: In need of some h16 parts [Re: Ian] #78000
06/20/06 11:57 AM
06/20/06 11:57 AM
davidtilley Offline
davidtilley  Offline
I presume the mast had water in which froze? If the crack is just a longitudinal split say 10" long, it would be easy to find someone to tig weld it up. The welding softens the aluminum but not critical at base of mast. Stress is toward the middle.
0 registered members (), 820 guests, and 27 spiders.
