| Rules Question: DNF vs. DNS vs. DSQ #8005 06/19/02 11:07 AM 06/19/02 11:07 AM | Anonymous OP
| Anonymous OP
Unregistered | Situation:
1. Sailor crosses the start at the 5-minute warning horn and continues around the race course;
2. Other 5 sailors start properly;
3. After 20 to 30 minutes, all sailors cross finish line, including the early bird, who crossed third.
Question:
Should the early bird be scored as a DNF, a DNS or a DSQ?
Specifically, when he crossed the finish line, did he in fact just cross the starting line (albeit 25 minutes late) to become a valid sailor in the race? Or is that time delay sufficient to warrant a DNS?
Alternately, can a sailor choose to disqualify himself from a race over a botched start? Or is the path of the boat the only thing that matters, not the skipper's intent? (i.e. "Your hulls crossed the starting line after the starting horn during the race, so you started, period.")
What do you folks think?
Taylor Simmons
Wicomico Beach Yacht Club (MD) | | | Re: Rules Question: DNF vs. DNS vs. DSQ
[Re: catman]
#8007 06/20/02 02:10 AM 06/20/02 02:10 AM | Anonymous OP
| Anonymous OP
Unregistered | Thanks Catman. But I'm still unclear why the act of crossing the start/finish line (albeit after first rounding the course in our early bird's case) doesn't constitute a proper start.
Is it the time delay? the circuitous route prior to? the sailor's intent?
How is this different from someone else who shows up late, hurries to get his boat rigged, and gets across the starting line 25 minutes behind the pack, but before the other boats have finished? | | | Re: Rules Question: DNF vs. DNS vs. DSQ
[Re: EasyReiter]
#8011 06/26/02 09:58 AM 06/26/02 09:58 AM | Anonymous OP
| Anonymous OP
Unregistered | Thanks Marcreiter (and CMerrell) for your posts.
I should point out that our scoring system is a bit different: Points are good -- you get a point for starting plus a point for each boat in the race that you beat, i.e. no points for boats that DNS. (So the Early Bird's DNF/DNS distinction does indeed matter for all sailors.)
Regarding being on course side (OCS), I don't think a penalty turn can absolve you -- you must re-start cleanly. Our early bird was OCS for most of his time on the water, but happened to stay clear of all other boats on the course, and did finally cross cleanly and then retired (signaling an intent not to re-complete the course).
Marc, when you say, "if you consider the second crossing a start 25 minutes late," that's precisely the issue. Is this consideration purely a judgement call by the race committee, rather than a specific rule that governs? I.e. there is no time deadline, nor a required route (back through starting line or around the mark and through again are each ok), but, in fact, an overall judgement by the RC based on both the facts and the sailor's apparent intent. Is this correct?
E.g. Suppose a boat's side stay snaps and his mast falls just after the starting horn (but before he starts), and he is obviously calling it quits, but happens to drift cleanly through the starting line on his way back to shore, does that count as a start? Should the race committee judge that boat as DNS, since the sailor evidently gave up before starting, even though technically the boat did cross the line? (If not, then what distinguishes this example from our Early Bird.)
Finally, does it matter what the sailor himself wants? ("Please give me a point for starting since technically I did." vs. "Please give me a DNS since obviously I wasn't going to do the race.") If it's purely a judgement call, then it seems that the sailor's wishes might indeed be an element considered by the RC, as long as they were consistent in such decisions over the season.
What do you think?
Thanks -Taylor Simmons | | | Re: Rules Question: DNF vs. DNS vs. DSQ
[Re: EasyReiter]
#8013 06/28/02 04:16 PM 06/28/02 04:16 PM | Anonymous OP
| Anonymous OP
Unregistered | Thanks again, Marcreiter, for your thorough examination. I really appreciate all the insight and help in resolving the issue.
Regarding the over-early flag described in 29.2, does that four minute limit represent a specific deadline by which an Early Bird must return to the pre-start side? Or does it just limit the courtesy of raising a flag to alert Early Birds of their offense -- so the RC's arms don't get tired holding it up for the whole race?
If actually the latter, would it be appropriate for a Race Committee to enforce a four-minute deadline for any Early Birds to remedy their transgressions?
Many thanks -TTS | | | Re: Rules Question: DNF vs. DNS vs. DSQ #8015 07/01/02 10:42 AM 07/01/02 10:42 AM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | No question that he messed up. No penalty turn would save him or we would all zoom over at the 5 minute horn, do our penalty turns and beat the pants off everyone. The real question is can he even be counted as running the race? It would only seem that he could be counted even as a late starter if he crossed the finishline in the same direction that the original race started. For example, on an upwind start, if he finished the race and crossed the line going downwind, then it seems he would be counted as never even starting at all.
CARY ACAT XJ Special C&C 24
| | | Re: Rules Question: DNF vs. DNS vs. DSQ #8016 07/01/02 06:58 PM 07/01/02 06:58 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Sometimes we make it so difficult.A yacht must properly start.It dosen't matter if it starts 25 min. late.It can't start early.Also its always better to start and score a DNF than a DNS.As I remember its one less point, and if it is a multiple race event with a throw out you can chuck the DNF not the DNS.
1 registered members (Team_Cat_Fever),
361
guests, and 94
