| Jake,
#81192 07/28/06 09:54 PM 07/28/06 09:54 PM |
Joined: Jan 2006 Posts: 195 Straight Outta Hell Boudicca
Posts: 195 Straight Outta Hell | It's not the number itself, but the way the whole system is supposed to work that is being treated unfairly.
Look at it this way. If you were entering data into an algorithm, and you entered data that was incorrect, eventually the outcome gets skewed.
Now if this boat, which is NOT an SX, gets rated as such and its finishes get entered into Darline's calculations, well, eventually either the SX or the base 18 is going to get its Portsmouth number calculated incorrectly.
People complain about the Portsmouth handicaps, yes? Not necessarily you, Jake, I don't know your opinion. But if incorrect data, or improperly utilized Portsmouth numbers or adjustments gets used, and then reported, and eventually taken into consideration into the yearly calc of the Ports no's... the wheel keeps on rollin' and it's garbage in, garbage out...
So, yes, it is about fairness to the competitors, but it's also about fairness to the SYSTEM.
See where I'm coming from?
sea ya tami | | | Re: Portsmouth question
#81195 07/30/06 11:31 PM 07/30/06 11:31 PM |
Posts: 1,459 Annapolis,MD | If your main is not class legal but less than 1.05 times the stock area you have to take an MN adjustment (0.995 * D-PN). If it is more than 1.05 times the stock area then you take an ML adjustment (0.98 * D-PN). A non-class legal sail is always assumed to be faster regardless of its size.
There is no official adjustment for non-class legal jib of same sail area or less.
A boat with a lower portsmouth number is faster, so you want a high number.
If your boat is class legal for Hobie 18SX other than the sails, then I think you can make a case that you should start out with the Hobie 18SX number. If it is not, then you do need to start out with the Hobie 18 number and take an additional hit for the spinn. This makes a big difference.
So it looks like if you start as a Hobie 18 you take an MN and SP adjustment. If you start as a Hobie 18SX you take an MN and JU adjustment. The latter will get you a higher number. You should double-check the sail area of the main though - "same sail area or less" is defined as less than 105% of the stock area. Did you notice that the TheMightyHobie18 SX (with spinnaker) rates a 71.3 and a regular 'ol Hobie 18 rates a 71.4. There's NO WAY you can start with an SX rating and be even remotely fair. I'd start by saying the SX ratings seem out of whack - looking back to the 2004 numbers they seem a little more reasonable. A question to Darline may clear that up. As for how to score and what's fair, I think you will find differences among people who do committee. Here's my take (as former 18 driver and weekly scoring dude for our Fleet): As for the boat - if the stick on the boat is a Hobie SX stick, I'd say you can start with an SX rating. The rig and spin is the only difference between a magnum and an SX. The wings are the only difference between an 18 and a Magnum. If the stick is some mast you found that just happens to be the same length, I'd start you from the magnum rating. If your spin rig is not stock SX, then take a mod hit for the major parts non-stock - ie one for the sail, one for the pole. Got a snuffer? Hit. Take a bonus for the smaller jib, take a hit for the non-stock main. Somebody could quibble if you have the old style wings versus the new style wings, I wouldn't. I don't believe it's necessary for you start with the boat as came from the factory for the base config for all cases. F-27 example - there was the "stock" 27 config, then people added the square tops, bigger jibs, transom extension/swim platform and asymetrical head sails, and the F-27 Formula was born. Later boats from the factory came that way (minus the platform). Earlier Boats with those mods simply sail as the Formula, not as F-27s with all the mods as factors, unless those mods don't measure in to the Formula parameters/measurements. My $0.02... | | | Re: Portsmouth question
[Re: Keith]
#81197 07/31/06 07:13 AM 07/31/06 07:13 AM |
Posts: 12,310 South Carolina | If your main is not class legal but less than 1.05 times the stock area you have to take an MN adjustment (0.995 * D-PN). If it is more than 1.05 times the stock area then you take an ML adjustment (0.98 * D-PN). A non-class legal sail is always assumed to be faster regardless of its size.
So it looks like if you start as a Hobie 18 you take an MN and SP adjustment. If you start as a Hobie 18SX you take an MN and JU adjustment. The latter will get you a higher number. You should double-check the sail area of the main though - "same sail area or less" is defined as less than 105% of the stock area. Did you notice that the TheMightyHobie18 SX (with spinnaker) rates a 71.3 and a regular 'ol Hobie 18 rates a 71.4. There's NO WAY you can start with an SX rating and be even remotely fair. I'd start by saying the SX ratings seem out of whack - looking back to the 2004 numbers they seem a little more reasonable. A question to Darline may clear that up. As for how to score and what's fair, I think you will find differences among people who do committee. Here's my take (as former 18 driver and weekly scoring dude for our Fleet): As for the boat - if the stick on the boat is a Hobie SX stick, I'd say you can start with an SX rating. The rig and spin is the only difference between a magnum and an SX. The wings are the only difference between an 18 and a Magnum. If the stick is some mast you found that just happens to be the same length, I'd start you from the magnum rating. If your spin rig is not stock SX, then take a mod hit for the major parts non-stock - ie one for the sail, one for the pole. Got a snuffer? Hit. Take a bonus for the smaller jib, take a hit for the non-stock main. Somebody could quibble if you have the old style wings versus the new style wings, I wouldn't. I don't believe it's necessary for you start with the boat as came from the factory for the base config for all cases. F-27 example - there was the "stock" 27 config, then people added the square tops, bigger jibs, transom extension/swim platform and asymetrical head sails, and the F-27 Formula was born. Later boats from the factory came that way (minus the platform). Earlier Boats with those mods simply sail as the Formula, not as F-27s with all the mods as factors, unless those mods don't measure in to the Formula parameters/measurements. My $0.02... You create a serious "rule beater" by applying the handicap this way. Realistically, this boat should only be a little slower than an F18 and it's rating should reflect that. By applying the rule as you have, you've given this boat a barely sub 70 rating while an F18 is 62.5. This boat would be impossible to beat under handicap by anything with a realistic rating. Even adding the full extent of mods to the regular Hobie 18 rating still looks a little soft but is certainly closer.
Jake Kohl | | | Rule beater
#81199 07/31/06 08:08 AM 07/31/06 08:08 AM |
Posts: 195 Straight Outta Hell | Jake sez: "You create a serious "rule beater" by applying the handicap this way. Realistically, this boat should only be a little slower than an F18 and it's rating should reflect that. By applying the rule as you have, you've given this boat a barely sub 70 rating while an F18 is 62.5. This boat would be impossible to beat under handicap by anything with a realistic rating. Even adding the full extent of mods to the regular Hobie 18 rating still looks a little soft but is certainly closer."
______________
I'm OSYC's PSVB (scorer) and I'd have to agree with Jake here. I don't think anyone is taking hull weights into account, though.
I should think that the 18/Magnum rating is pretty well established since the 'original' 18 has been around for some time. The 18sx is much newer, and fewer of them around, so I'd be disinclined to trust the number as compared to the stock 18 rating.
The 18SX, being a newer boat, prolly has much lighter hulls, too, and of course weight is a big factor.
As far as I'm concerned, I believe that the -platform- is what the boat is, not its -rig-. Using Keith's logic, one could take a set of NACRA 5.5 hulls and add a Hobie 18SX rig and take the SX rating. Now wouldn't THAT be a rule beater?
What is definitely apparent from this debate is that the Ports. ratings are being applied in quite a subjective way, but then so is PHRF, but that's another argument. ;-)
And Keith, about my F27GS? I start with the Formula rating, and take hits for bigger sails, rotating mast, taller stick, lightened/reshaped hulls, and modified rudder, I guess. I haven't worked out Ports. yet, oi...
#81200 07/31/06 08:21 AM 07/31/06 08:21 AM |
So it looks like if you start as a Hobie 18 you take an MN and SP adjustment. If you start as a Hobie 18SX you take an MN and JU adjustment. The latter will get you a higher number. You should double-check the sail area of the main though - "same sail area or less" is defined as less than 105% of the stock area. Did you notice that the TheMightyHobie18 SX (with spinnaker) rates a 71.3 and a regular 'ol Hobie 18 rates a 71.4. There's NO WAY you can start with an SX rating and be even remotely fair. I'd start by saying the SX ratings seem out of whack - looking back to the 2004 numbers they seem a little more reasonable. A question to Darline may clear that up. As for how to score and what's fair, I think you will find differences among people who do committee. Here's my take (as former 18 driver and weekly scoring dude for our Fleet): As for the boat - if the stick on the boat is a Hobie SX stick, I'd say you can start with an SX rating. The rig and spin is the only difference between a magnum and an SX. The wings are the only difference between an 18 and a Magnum. If the stick is some mast you found that just happens to be the same length, I'd start you from the magnum rating. If your spin rig is not stock SX, then take a mod hit for the major parts non-stock - ie one for the sail, one for the pole. Got a snuffer? Hit. Take a bonus for the smaller jib, take a hit for the non-stock main. Somebody could quibble if you have the old style wings versus the new style wings, I wouldn't. I don't believe it's necessary for you start with the boat as came from the factory for the base config for all cases. F-27 example - there was the "stock" 27 config, then people added the square tops, bigger jibs, transom extension/swim platform and asymetrical head sails, and the F-27 Formula was born. Later boats from the factory came that way (minus the platform). Earlier Boats with those mods simply sail as the Formula, not as F-27s with all the mods as factors, unless those mods don't measure in to the Formula parameters/measurements. My $0.02... You create a serious "rule beater" by applying the handicap this way. Realistically, this boat should only be a little slower than an F18 and it's rating should reflect that. By applying the rule as you have, you've given this boat a barely sub 70 rating while an F18 is 62.5. This boat would be impossible to beat under handicap by anything with a realistic rating. Even adding the full extent of mods to the regular Hobie 18 rating still looks a little soft but is certainly closer. I can say that I honestly believe from experience that a Hobie-18 rigged this way will not be even close to the rated speed of an F-18. I also still say that the current SX rating looks out of whack given what the rating was in 2004. So maybe a more realistic rating can be acheived the other way, but I don't necessarily agree with the logic. I know some folks that sailed the SX and the only comments I've heard about the boat is that it never lived up to its promise. Given the weight of the boat, the windage and weight of the wings, the hull shape, the boards, etc. Then take that the main he's using is not bigger than the SX main, and the jib being used is smaller. One speed limiter I always found on the 18 was the low freeboard to the hulls and the hull/deck lip getting in the waves. The F-18 boats have a better hull configuration, more efficient boards, lighter weight, etc. Don't get me wrong, I loved my 18, and the with the spin it was fun. But I don't think you'll get it that fast without more mods than listed here. | | | Re: Portsmouth question
[Re: Keith]
#81201 07/31/06 09:48 AM 07/31/06 09:48 AM |
Posts: 12,310 South Carolina | Geeze - how heavy is a Hobie 18? I thought it was just over 400lbs.
Jake Kohl | | | Re: Portsmouth question
#81202 07/31/06 10:35 AM 07/31/06 10:35 AM |
Posts: 1,459 Annapolis,MD | Geeze - how heavy is a Hobie 18? I thought it was just over 400lbs. That's about right. Some seemed to push 450 without wings (mine seemed to). Add around 40 or so for the wings. I thought that's more than an F18 - I know they're no A-Cat but I didn't think they're 400lbs. If so I'll stand somewhat corrected on that point. | | | Re: Jake,
[Re: Boudicca]
#81203 07/31/06 10:46 AM 07/31/06 10:46 AM |
Posts: 308 Reno NV | Now if this boat, which is NOT an SX, gets rated as such and its finishes get entered into Darline's calculations, well, eventually either the SX or the base 18 is going to get its Portsmouth number calculated incorrectly.
I really hope US sailing is not using numbers from boats like this in their Portsmouth calculations - if they are it's a wonder the numbers are as good as they are. Boats with any modifications let alone two shouldn't be used in calculating the base numbers, only used for evaluating the modification factors. For example, last race I was at there was a Prindle 18-2 that was cut down to 16' and sailed with Prindle 16 rig. It was very slow (slower than the Prindle 16s) but was given the same number as an 18-2. If US sailing uses those results that will bring the 18-2 number up, which would be silly. Better to just ignore that result together (and yes, the score keeper noted what was up with that boat in the results he submitted to Darlene). Anyway, it is important to me to be nice to the newcomers and not piss them off by giving them a number that the boat can't sail to. Maybe the rest of you have enough people showing up at your regattas that you can afford to do that. Except for classes that have been actively raced for many years, "fairness" and "portsmouth" are mutually exclusive anyway. The F16's legitimate portsmouth number gives me far more heartache than any modified/homebuilt boat ever did. | | | Re: Portsmouth question
[Re: WindyHillF20]
#81205 07/31/06 11:16 AM 07/31/06 11:16 AM |
Posts: 1,459 Annapolis,MD | The boat was weighed last year with wings on, 28' mast and dacron sails at 438lbs. 28' mast is solid, 29'6 has comptip. What about downhaul ( 8:1 ) and mainsheet ( 8:1 ), aren't these allowable now? No hits? Also according to Hobie the Tiger main is larger than a SX main. I'm a crappy racer and don't expect to surprise anyone. Just trying to represent the boat properly Yours is lighter than mine was for sure.... If the Tiger main is bigger than the SX main than take that hit either way you baseline it. I remember there was an upgrade allowed on the downhaul, don't recall if there is on the mainsheet. If not specifically allowed in the rules, then not legal and you would most likely take a hit. | | | Re: Portsmouth question
[Re: WindyHillF20]
#81206 07/31/06 11:24 AM 07/31/06 11:24 AM |
Posts: 1,187 38.912, -95.37 | HCANA rules are 8:1 downhaul, 7:1 main blocks.
I'll agree you're closer to being an SX than a stock 18.
[Re: Keith]
#81208 07/31/06 11:40 AM 07/31/06 11:40 AM |
Posts: 12,310 South Carolina | Geeze - how heavy is a Hobie 18? I thought it was just over 400lbs. That's about right. Some seemed to push 450 without wings (mine seemed to). Add around 40 or so for the wings. I thought that's more than an F18 - I know they're no A-Cat but I didn't think they're 400lbs. If so I'll stand somewhat corrected on that point. F18 minimum weight is 396lbs for the boat.
[Re: _flatlander_]
#81209 07/31/06 11:41 AM 07/31/06 11:41 AM |
Posts: 12,310 South Carolina | HCANA rules are 8:1 downhaul, 7:1 main blocks.
I'll agree you're closer to being an SX than a stock 18. Is it about what configuration it's closer to or what number is fair? Being that a competition handicap system is to try and make competition "fair", it should be the latter. You are basically giving the boat a free spinnaker power-up by using the SX rating. In light stuff, a well sailed Hobie 18 can keep pace upwind with F18s and the below the waterline shape is similar to the Tiger but with much fatter boards. I haven't sailed along side a TheMightyHobie18 in anything else yet.
#81210 07/31/06 11:57 AM 07/31/06 11:57 AM |
Posts: 1,187 38.912, -95.37 | Whoa!! I just checked the tables again and didn't realize it was 18SX with spi
My statment was predicated on there is no difference in the boats when "spi-less", other than the standing rigging/sail plan, hulls and frame are identical.
We've kept pace with (and passed) H20's upwind (combined start)...at the weather mark they left us like beached whales. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
1 registered members (nutsy),
320
guests, and 33
