| Blade Dagger Board #83362 08/23/06 08:47 AM 08/23/06 08:47 AM |
Posts: 71 | Has anyone drilled out the obvious hole location for a retrieval line in the Blade Dagger boards?
I think this is what was originally used by the Taipan to raise the boards.
Stephen
Stephen Phoenix Az | | | Re: Blade Dagger Board
[Re: Stephen]
#83363 08/23/06 02:30 PM 08/23/06 02:30 PM |
Posts: 67 Netherlands | I do have drilled the hole locations on my Blade, no problem. What you probably also need is this eyelet: ![[Linked Image]](http://www.gruesink.demon.nl/eyelet.jpg) Otherwise you risk the retrieval line getting jammed between the daggerboard and the hull. Geert | | |
369
guests, and 46
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
