| Re: Tangled Traps
[Re: pdwarren]
#87665 11/01/06 04:59 PM 11/01/06 04:59 PM |
Posts: 6,049 Sebring, Florida. | As Paul mentions, usually if you put more tension on the bungee cord it will sort out the tangle while you are sailing on the other tack....usually.
Blade F16 #777
| | | Re: Tangled Traps
[Re: pdwarren]
#87670 11/02/06 05:45 AM 11/02/06 05:45 AM |
Paul,
indeed best way to reduce forward pull is to length the bungee attached to the trap wire.
In my experience it is best to have the bungee go underneath the tramp then run to the other side, run over a small block that is attached to the underside of the tramp then back to the first side, run over a small block under the tramp there and only then go to the trap line on lee.
This increases the bungee length from about 2.5 mtr to roughly 4.25 mtr. The pull on the line is now much more constant, meaning you have more pull on the trap line when it is not in use while having less pull when the trap line is used.
The next step is using 4 mm bungee line instead of 5 mm. This seemed to have solved the remainder of the issues.
Attaching the small blocks to the underside of the tramp can be done by stitching small loops to it (sailmaker) and then using a tie wrap to attach the block to the loop.
| | | Re: Tangled Traps
[Re: Glenn_Brown]
#87675 11/02/06 12:54 PM 11/02/06 12:54 PM |
Posts: 371 Michigan, USA | Glenn,
That pigtail is for the crew trap line. I like the one the skipper uses. It just comes up through the grommet in the tramp and keeps it clear of the shroud. There is no added block, just route without going to the fairlead at the edge of the hull. I would give this a try before anything else because it is so simple. If you like it, remove the fairlead so you won't sit on it <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />. Its a PITA...literally!
Les Gallagher
| | | Re: Tangled Traps
[Re: sparky]
#87676 11/02/06 04:39 PM 11/02/06 04:39 PM |
Posts: 465 Oxford, UK | I like the one the skipper uses. It just comes up through the grommet in the tramp and keeps it clear of the shroud. Nah - that's what I hate about the Tiger setup. We found it impossible to get our weight forward without getting tangled up in the traps. The Blade setup keeps them nicely out of the way - occasionally unwrapping it from the shroud is a small price to pay. Each to their own, I guess, but I can't remember a light wind sail on the tiger that didn't involve many cries of "f**king trapezes". Paul | | | Re: Tangled Traps
[Re: pdwarren]
#87677 11/03/06 12:28 AM 11/03/06 12:28 AM |
Posts: 205 Melb. Aust | The Mosquito trap is (almost) ideal in placement - Crew wire comes out of the main beam and the Skipper wire exits from the tramp about two thirds the way back. The crew can use the slightly longer rear wire on reaches and the only forward pull is from the mast! (or sudden deceleration). This puts the wire far enough from the shroud so it doesnt tangle and there is enough room to get around it when going about. ...now if I could only stop the stainless parts from smacking me in the head when not hooked up...
Mozzie 1828 ' ' Sugarloaf Sailing Club Melbourne
| | | Re: Tangled Traps
[Re: pdwarren]
#87678 11/03/06 03:13 AM 11/03/06 03:13 AM |
Joined: Sep 2001 Posts: 254 Gower, Wales, UK sailwave
Posts: 254 Gower, Wales, UK | Each to their own, I guess, but I can't remember a light wind sail on the tiger that didn't involve many cries of "f**king trapezes".
Gosh, I simply can't imagine Ann swearing like that <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | | Re: Tangled Traps
[Re: sailwave]
#87679 11/03/06 07:01 AM 11/03/06 07:01 AM |
Posts: 465 Oxford, UK | Indeed not - that was with Steve on the Tiger. Language on the Blade is nothing short of exemplary at all times. No, really. Nothing at all like these fine fellows: http://www.youtube.com/watch?v=NHxFBjkaoYM(the description of the gust at around 2:50 is nothing short of... Australian <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> ) Paul | | | Re: Tangled Traps
[Re: Robi]
#87681 11/03/06 12:27 PM 11/03/06 12:27 PM |
Posts: 6,049 Sebring, Florida. | Nice windward takedown too! Do not try that at home on your cat! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Blade F16 #777
1,174
guests, and 41
