| Should I use the mainsheet cleat #8924 07/20/02 12:15 AM 07/20/02 12:15 AM |
Joined: Jul 2002 Posts: 170 Australia Jules_topcat OP
Posts: 170 Australia | Hi,
I went down the coast and sailed in winds at about 25 nots (great fun). My problem is i cant cleat off the main when my arm gets tired. I know im not ment to cleat it off but since im only 16 my arm gets tired in strond winds? I think tyhe cleat is too high to lock off but when i put it down a hole i can unlock it can some one give me some view's of how to over come this.
Thanks, from Julian
(p.s i sail a hobie 16 for 2 years and in most races finish in the top 10 percent)
Jules_topcat
| | | Re: Should I use the mainsheet cleat
[Re: Hobie Dave]
#8928 07/23/02 07:49 AM 07/23/02 07:49 AM |
Posts: 170 Australia | I tryed the pulling in to the wind and blocking it but since i live in canberra australia this doesn't work to well but I think this technipue take's practice. I sail on a lake which isn't very wide say 50meters but very long. I put the cleat down a hole and was to low to uncleat, even if i was on the tramp I couldn't uncleat it. My crew and i have tryed to tamper with the block to change the angle but didn't turn out so well so is there some thing to angle the cleat/block better?
Jules_topcat
[Re: Jules_topcat]
#8930 07/24/02 12:56 PM 07/24/02 12:56 PM | Anonymous
| Anonymous
Unregistered | Jules, You did not mention if you are using good sailing gloves, such as Trophy. Gloves will really increase your ability to hold a mainsheet while going to strong weather.
You can also wrap the sheet around your hand an extra loop, but I'd only recommend this if you are good at detecting a puff and can release it quickly.
Good sailing! | | | Re: Should I use the mainsheet cleat #8931 07/25/02 05:38 AM 07/25/02 05:38 AM |
Posts: 170 Australia | The gloves im using are gill good gloves but thats not my problem, the problem is i cant cleat the main and cant realy hold on to the main sheet for to long. Like im not paying you out o any thing im just wondering if im missing some thing? Well i appreciate all the help you people have given me thanks again.
From Jules
Jules_topcat
[Re: Bogie]
#8934 08/02/02 03:34 AM 08/02/02 03:34 AM |
Posts: 170 Australia | Sorry for the taking so long but I had no time. Well the block has no name but i knoe its a harken. It looks old say 10years.
I tried most of those techniques and well they didn't work as well as hoped I went over with my girlfriend and she said she wont sail with me ever again (I bet she will). Well would you suggest a new block? Because im thinking it could be that.
From Jules
Jules_topcat
[Re: Jules_topcat]
#8935 08/03/02 07:35 AM 08/03/02 07:35 AM |
Posts: 97 | Sounds like it might be an older system. You might take a look at a new set of blocks first, to see if this could help your problem. You might be able to replace just the cleats, if you can find them. I don't know if ordering from www.murrays.com would be a cost effective solution in your area, but I'm pretty sure they carry them. | | | Re: Should I use the mainsheet cleat
[Re: Greg]
#8937 08/20/02 03:00 AM 08/20/02 03:00 AM |
Posts: 170 Australia | Yes its always good to clean and spray your block i do this almost every time i go out. But thats not my the problem, its that the cleat is in such a position i cant cleat from trapeze and well the only time i can is when im traping off the back off the boat down wind.
From Julian
Jules_topcat
[Re: Berthos]
#8939 08/21/02 02:55 AM 08/21/02 02:55 AM |
Posts: 170 Australia | hey
no i dont think it has, the block looks about 10years old and its probaly the original. The boat when i first bought it, it looked like it had all the original gear and so far i have replace a whole lot of things. I think the problem is the angle of the block i cant move the cleat higher or lower but i dont know how to reangle the block. If any one can help it would be a great help.
Jules
Jules_topcat
597
guests, and 45
