Rudderless steering #91607
12/08/06 08:58 PM
12/08/06 08:58 PM
Thailand
Buccaneer Offline OP
Thailand
Hey, has anybody noticed any particular characteristics or tendencies for operation without use of rudders and/or boards? For example during shallow rocky water beach entry/exit etc. and various off shore/on shore wind conditions. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Rudderless steering [Re: Buccaneer] #91608
12/09/06 03:29 AM
12/09/06 03:29 AM
Just steer with your sails.
If you're uni then you can steer by moving around the boat. If you go aft and to windward and ease your main right out you'll bear away, move slightly forward, inboard and sheet in you'll point up.
All boat designs behave slightly differently so it's a question of experimenting.
Re: Rudderless steering [Re: Jalani] #91609
12/09/06 03:50 AM
12/09/06 03:50 AM
If it is blowing offshore and you are going out over a stretch of shallows, hoisting the kite enables you to sail out instead of walking the boat out. It also impress your competitors a lot when you zip past them at 15knots, rudderless.
The same can be done when going in, but its harder to find the right balance between sailtrim and crew weight.
Practice in an open area before trying it close to shore/obstacles/navigational hazards! It is easiest to get going on a reach. Learning to control your boat without rudders give a new feel for the boat, and is a good way to become faster on the racecourse. Johns post sums it up very well.
Re: Rudderless steering [Re: Jalani] #91610
12/09/06 04:29 AM
12/09/06 04:29 AM
When we got our first catamaran, a Shark, back in 1961 or so, my father actually took the rudders completely off the boat and sailed it all over the place with no rudders. He did it to prove how well balanced the boat and its sail plan was.
I think everyone should practice sailing with their rudders up (taking them off completely is a little radical). It gives you a new appreciation for how much more influential the sails and weight distribution are than are those relatively tiny rudders in the back of the boat. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Granted, it is a LOT easier to do with a sloop rig than with a uni-rig. I guess you would have to throw your weight around a whole lot more with a uni-rig.
They do have that class of cats in Europe (Patin a Vela, I think) that race and do not have any rudders. I would think you have to be very athletic, because it is all in the weight distribution.
Re: Rudderless steering [Re: Buccaneer] #91611
12/09/06 07:19 PM
12/09/06 07:19 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
This brings up a great training exercise--steering w/o the rudders, just steering w/ sails only.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Rudderless steering [Re: ejpoulsen] #91612
12/09/06 11:53 PM
12/09/06 11:53 PM
Thailand
Thailand
Even more of a challenge with the boards up unless your going downwind. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
For solo beach entry I normally let out the traveler and try to get the windward board down just a couple inches ASAP as I position my weight inboard slightly aft until I can get the rudders down. Just keep her going straight!
I noticed on the Taipan, in emergency it’s even possible to steer with the rudders up by moving crew weight as far aft as possible and windward.
Not sure I'd try beach entry/ exit with the kite just yet... <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Rudderless steering [Re: Mary] #91613
12/14/06 01:25 PM
12/14/06 01:25 PM
Scotland
George_Malloch Offline
Scotland
So as things would happen, there I was walking along the beach by the Club Natació Barcelona on Tuesday when I chanced (as one does) on these beasts. They are, as Mary said Patin a Vela. No rudders, no boards, no boom, no battens, no trapeze. All wood (including the fives beams), they look quite long, maybe 18 or 20 feet but are much narrower than you'd expect from a conventional cat. The mast is aluminium and doesn't appear to rotate. It has three sets of shrouds/stays - the middle ones are fixed but the others are adjustable on the water. The mast is very bendy, the mainsheet is only 3:1 but the helmsman can bend the mast by a huge amount. They do have a travelled but no way on controlling where the mainsheet is on it - so it's always down to leeward. The day I watched them was very light. Whilst the better sailors had no problems, the poorer guys were struggling a bit, quite a few blown tacks and a few accidental ones where gusts came through!
Stealth www.peyc.org.uk
Re: Rudderless steering [Re: George_Malloch] #91614
12/14/06 01:28 PM
12/14/06 01:28 PM
Scotland
Scotland
This shows the shrouds and the adjustments for them a bit better.
Re: Rudderless steering [Re: George_Malloch] #91615
12/14/06 01:31 PM
12/14/06 01:31 PM
Scotland
Scotland
This shows one sailing (although there was hardly any wind at the time). Upwind the trick seemed to be to sit really far back, I guess to dig the deep sterns into the water
Re: Rudderless steering [Re: George_Malloch] #91616
12/14/06 03:06 PM
12/14/06 03:06 PM
Thanks for the pictures, George.
Re: Rudderless steering [Re: George_Malloch] #91617
12/14/06 03:39 PM
12/14/06 03:39 PM
So it would appear that they actually rake the mast forward/back whilst sailing to trim the boat? - a bit like a windsurfer then?
Cool looking vessel, exactly the sort of challenge I'd relish <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> although I guess I'd be one of those 'poorer guys' <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Yes, thanks for the pics George.
Re: Rudderless steering [Re: George_Malloch] #91618
12/15/06 03:58 AM
12/15/06 03:58 AM
Mark P Offline
Mark P  Offline
No rudders would have its advantages, a spare hand to light cigarettes and drink lots of beer <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />. Seems like my sort of cat. Do they make 16ft versions with kites?
MP*MULTIHULLS
0 registered members (), 306 guests, and 86 spiders.
Posts267,059
