Beach wheel flat tires #92097
12/13/06 10:34 AM
12/13/06 10:34 AM
Crofton, MD
Todd Berget Offline OP
Crofton, MD
Anybody know of a cheap fix for beachwheels. I have a set of Cat trax with a flat. I was thinking of trying fix-a-flat but wondered if anyone else had any ideas?? I'd rather spend $125 on some new blocks or something rather than a new wheel.
Todd Nacra 20 www.wrcra.org
Re: Beach wheel flat tires [Re: Todd Berget] #92098
12/13/06 10:45 AM
12/13/06 10:45 AM
41.32 N, 81.35 W
Stuart_Douglas Offline
41.32 N, 81.35 W
What kind of wheels do Cat Trax have and what's the cause ff the leak? If they're inflatable, wouldn't you be able to use a simple patch or plug repair kit and then reinflate?
Re: Beach wheel flat tires [Re: Todd Berget] #92099
12/13/06 10:58 AM
12/13/06 10:58 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
It's probably leaking through the valve stem. I've used 5200 to reseal the stem with marginal success.
F18 USA 242
http://www.solarwind.solar
Re: Beach wheel flat tires [Re: Todd Berget] #92100
12/13/06 11:28 AM
12/13/06 11:28 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I've been through this many times. Fix-a-flat doesn't work because the wheels never travel at any speed. You are supposed to put he fix-a-flat in and then drive to spread it around.
Put tubes in the tire that's leaking. Go to a tire place that can handle it. Not all have the proper machine for doing this. I've been charged anything from $15 to $60 dollars so shop around. The most expensive places were ATV dealers. The cheapest was Tire America here in town.
If you use your wheels in salt water the valve stem will corrode and need to be replaced every few years.
Mike Hill
www.stlouiscats.com
Re: Beach wheel flat tires [Re: Todd Berget] #92101
12/13/06 12:07 PM
12/13/06 12:07 PM
Graham, NC
WindyHillF20 Offline
Graham, NC
I've encountered 2 culprits. First is the valve stem, either the core is bad or the stem itself is leaking. Both can be replaced. The other is the bead where the tire seals to the rim, remove the tire and clean or repair the bead. If neither of these work a tube is the only option. Still cheaper than a new assembly.
Re: Beach wheel flat tires [Re: Todd Berget] #92102
12/13/06 01:30 PM
12/13/06 01:30 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
I have put tubes in both tires on my catrax. I bought the tubes from these guys online after I couldn't find the right size tube locally. They were very prompt sending it to me. I think it cost me about $28.00 for each (including delivery). No problems to date.
http://www.jackssmallengines.com/index_tubes.html
Don Cook ARC22 #2226 ADRENALIN
Re: Beach wheel flat tires [Re: Todd Berget] #92103
12/14/06 12:24 PM
12/14/06 12:24 PM
Northern VA
bsquared Offline
bsquared  Offline
Northern VA
I found a tube close to the right size at a lawnmower place. Also had to get a valve stem extension because the tube would draw in as it was inflated. Works fine for low speed/low pressure cat work :-) I didn't have too much trouble popping the bead loose with a block of wood and a hammer. Pretty cheap long-term fix.
Re: Beach wheel flat tires [Re: bsquared] #92104
12/20/06 02:19 PM
12/20/06 02:19 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I have had the stem problem before. The metal part of the stem starts to corrode and releases from the rubber causing the whole thing to slip out. The best solution that I could find for it was GOOP. I took the stem out cleaned it up with some sand paper. Made sure that most of the powdery stuff in the rubber part of the stem was scraped out. Glued the metal stem in careful not to get any glue in the inflation valve. It has worked for over a year. I did contact the lawnmower shop to see what they can do for me. Maybe the next time I lose a stem I will put an innertube in.
Later,
Dan
Re: Beach wheel flat tires [Re: Dan_Delave] #92105
12/20/06 02:43 PM
12/20/06 02:43 PM
41.32 N, 81.35 W
41.32 N, 81.35 W
GOOP is the elixir of the gods...I can't think of how many things I've fixed with that stuff. Required supply item for every household.
Re: Beach wheel flat tires [Re: Todd Berget] #92106
12/20/06 03:47 PM
12/20/06 03:47 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
what about tubeless tire replacements? I have a tire and a wheel with a flat, no valve stem opening, no tube(says tubeless on the side.) Will the local tire shop know how to fix this, and what if it has a leak? How do you fill it back up? I see nothing on the tire to fill it back up with.
Re: Beach wheel flat tires [Re: dave mosley] #92107
12/20/06 05:11 PM
12/20/06 05:11 PM
claus Offline
claus  Offline
I would try the same stuff they use to fix tubeless motorcycle tyres. This is sort of a rubberstick which is inserted in the hole and then torn out and vulcanized. Should work on a beach wheel.
Re: Beach wheel flat tires [Re: dave mosley] #92108
12/20/06 05:20 PM
12/20/06 05:20 PM
and if a tree falls in the woods but nobody is around to hear it, does it make a "sound"?
Re: Beach wheel flat tires [Re: Jake] #92109
12/20/06 06:02 PM
12/20/06 06:02 PM
dave mosley Offline
dave mosley  Offline
maybe...
If 4 out of 5 people in America suffer from Diarrhea, does the 5th person enjoy it?
Re: Beach wheel flat tires [Re: dave mosley] #92110
12/20/06 09:33 PM
12/20/06 09:33 PM
NC
drbinkle Offline
drbinkle  Offline
NC
maybe...
If quitters never win, and winners never quit, can you "Quit while you're ahead"?
Re: Beach wheel flat tires [Re: dave mosley] #92111
12/20/06 09:49 PM
12/20/06 09:49 PM
Seriously? This thing doesn't have an air valve? Tubeless just means that the bead of the tire is meant to seal air-tight to the rim and doesn't require an inner-tube.
Re: Beach wheel flat tires [Re: Jake] #92112
12/21/06 07:45 AM
12/21/06 07:45 AM
Commerce, MI
tigerboy1 Offline
tigerboy1  Offline
Commerce, MI
Jeremy Leonard of Surf City Catamarans in Santa Cruz, CA has a slick method of taking flat tubeless beach wheels and inserting a inner tube. Works great and I've haven't had a problem since. I've tried cans of fix-a-flat but only got a temporary repair. Another area to check is the valve stems. Sometimes the rubber cracks over time allowing the air to bleed off.
Re: Beach wheel flat tires [Re: Jake] #92113
12/21/06 04:19 PM
12/21/06 04:19 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
If I am standing in the middle of the forest talking to myself and my wife is 100 miles away, am I still wrong?
Re: Beach wheel flat tires [Re: arbo06] #92114
12/21/06 04:20 PM
12/21/06 04:20 PM
most certainly.
Re: Beach wheel flat tires [Re: Jake] #92115
12/22/06 07:25 AM
12/22/06 07:25 AM
dave mosley Offline
dave mosley  Offline
Jake, youre a newly wed, surely you are "still right" on occasion....
Re: Beach wheel flat tires [Re: arbo06] #92116
12/22/06 08:28 AM
12/22/06 08:28 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
sounds just about right
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 622 guests, and 62 spiders.
