| Re: Broken Gudgeon Bolts
[Re: peter]
#96862 01/20/07 10:54 PM 01/20/07 10:54 PM |
Posts: 12,310 South Carolina | Does the P19 have threaded plates molded in the hulls for the gudgeons? All the other Performance Cats (Nacra, Inter) have nuts and big washers (through drilled aluminum plates) that are loose on the inside of the hulls. Nothing is actually tapped and/or molded in the hull for the gudgeons so the hulls just have through holes.
You've checked to make sure there are not nuts on the inside right?
Jake Kohl | | | Re: Broken Gudgeon Bolts
[Re: MauganN20]
#96870 01/22/07 01:54 AM 01/22/07 01:54 AM |
Posts: 36 MOBILE, AL. | I ran across the same problem on my P-19 MX... Take your dremel with a small routor bit & route around the bolt . I mean right up against it. Go all the way thru the hull. Fill the holes back with epoxy . Drill new holes & replace the the bolts with new stainless bolts & nuts. You will have to drill the holes out in the plate . Dont use the same set-up ... The corrosion problem will happen again. Stainless & aluminum weld together after awhile in the salt. If it's not clear on how to do this just let me know. Doug <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
SOUTHERN CROSS FIBERGLASS, LLC.
9301 HWY. 90 EAST
MOSS POINT, MS. 39581
251-473-8159 DOUG KLEM
[Re: davidtilley]
#96873 01/22/07 10:46 AM 01/22/07 10:46 AM |
Posts: 168 San Diego | If you have some decent drill bits, try drilling through the bolt itself with a small bit and then work your way up to a larger one. | | | Re: Broken Gudgeon Bolts
[Re: srm]
#96877 01/22/07 11:49 AM 01/22/07 11:49 AM |
Posts: 168 San Diego | make sure to liberally apply cutting oil (3in1 household oil) when drilling through the metal | | |
484
guests, and 33
