Going the Hardway? #99696
02/23/07 04:55 PM
02/23/07 04:55 PM
sbp19 Offline OP
sbp19  Offline OP
So as my user name suggest, I sail a P-19 out of Santa Barbara. I've been considering sailing the Hardway Race this year. I've sailed out to "C" before, so I feel like I've got a fair grasp of what it would be like. What do I need to get ready? Things I should know in advance?
Talk me into this!!!
Re: Going the Hardway? [Re: sbp19] #99697
02/23/07 06:32 PM
02/23/07 06:32 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Last year the Hardway race was opened to beachcats for the first time in recent memory. It was a good race with 8 or 9 boats of different classes (prindle with spinny, several I20's, Nacras and my T with spinny) entering. Due to safety concerns of the RC, the beachcats sailed the inside course...around several oil platforms and into ventura harbor. Took us about 4-5 hours to complete the 35+ mile distance in a light wind day.
I recommend you enter. Check out the latest details on the sailing instructions for required equipement (drinking water, flashlight, marine radio, tow line, flares etc).
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Going the Hardway? [Re: Tornado] #99698
02/27/07 12:20 PM
02/27/07 12:20 PM
Santa Barbara CA
sbflyer Offline
sbflyer  Offline
Santa Barbara CA
Go for it. I was driving the P 19 w/ spin last year, but without spin it would have sucked! We had it up 90% of the race and without it we would have been there after dark! Going the right direction helps too, as the two I 20's we beat boat for boat found out...
Re: Going the Hardway? [Re: sbflyer] #99699
02/27/07 01:38 PM
02/27/07 01:38 PM
sbp19 Offline OP
sbp19  Offline OP
I am in the process of adding a F-18 spinn to the boat, so that should help.
Re: Going the Hardway? [Re: sbp19] #99700
02/27/07 04:16 PM
02/27/07 04:16 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Just make sure you visit the US sailing Portsmouth modification tables to work out the right handicap number to use...wouldn't want you beating me with a "fudged" number <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Glad to hear you're coming out!
Mike.
Mike Dobbs
Re: Going the Hardway? [Re: sbp19] #99701
03/01/07 05:29 PM
03/01/07 05:29 PM
Coral Gables, Fl
ferminj Offline
ferminj  Offline
Coral Gables, Fl
I am also adding a F18 spinnaker to my P19. Do you have any pixs?. I am wondering about the spinn halyard cleat (I'm going to use a harken cam cleat on the mast) and the pole to front xbar connection.(Small gudgeon and a U bracket on the pole end).
Re: Going the Hardway? [Re: ferminj] #99702
03/02/07 04:30 PM
03/02/07 04:30 PM
sbp19 Offline OP
sbp19  Offline OP
I haven't got it setup yet, but the first owner had one setup on it, so some of the parts are already there.
I'm using a "standard" pin on a plate rivited to the front beam to attach the pole. and using a cam cleat on the front beam for the halyard as it is already there.
If you look at the performance F-18/N-20 manual it will give you some good ideas about how to set it up.
Re: Going the Hardway? [Re: sbp19] #99703
03/02/07 04:31 PM
03/02/07 04:31 PM
sbp19 Offline OP
sbp19  Offline OP
Mike,
I'll check out the rating issue.
0 registered members (), 534 guests, and 34 spiders.
