| Main halyard Stealth F16 trouble #105270 04/29/07 03:22 PM 04/29/07 03:22 PM |
Joined: Jan 2006 Posts: 23 Bjärred, Sweden Pontus_Lofgren OP
Posts: 23 Bjärred, Sweden | I was raising my main sail the other day (for the first time) it got stuck and I had a hard time getting it either up or down. In the end the halyard was "wasted". So now I have to get a new halyard. I thought that the reason for the trouble was that the halyard ran inside the mast and that it got stuck somewhere before the block on top of the mast, but when i had a closer look at the mast top i saw that it cannot run outside the mast due to the placement of block at the top of the mast. Did I just had bad luck when the halyard got stuck? I thought that it should be quite easy to raise the main compared with my old Hobie 16. -The main halyard should run inside the mast, correct? -How think should it be, 4mm or less so that it does not get stuck? -Is 20 meter sufficient?
BR Pontus
Stealth F16
NED 535
| | | Re: Main halyard Stealth F16 trouble
[Re: Pontus_Lofgren]
#105271 04/29/07 04:03 PM 04/29/07 04:03 PM |
Posts: 3,528 Looking for a Job, I got credi... | I was raising my main sail the other day (for the first time) it got stuck and I had a hard time getting it either up or down. In the end the halyard was "wasted". So now I have to get a new halyard. I thought that the reason for the trouble was that the halyard ran inside the mast and that it got stuck somewhere before the block on top of the mast, but when i had a closer look at the mast top i saw that it cannot run outside the mast due to the placement of block at the top of the mast. Did I just had bad luck when the halyard got stuck? I thought that it should be quite easy to raise the main compared with my old Hobie 16. -The main halyard should run inside the mast, correct? -How think should it be, 4mm or less so that it does not get stuck? -Is 20 meter sufficient?
BR Pontus Pontas, The halyard runs down the inside of the mast track on my boat (new last year) and I assume yours is the same. Mine is 3mm I think 20m should be enough as the mast is less than 10m high ! Edit to add "track"
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Main halyard Stealth F16 trouble
[Re: bobcat]
#105275 04/29/07 04:52 PM 04/29/07 04:52 PM |
Posts: 1,246 Orlando, FL | Robi,
He said bolt ROPE! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
USA 777
[Re: tback]
#105276 04/29/07 10:12 PM 04/29/07 10:12 PM |
Posts: 1,479 Thailand | Why the need for the convoluted halyard? Seems to me like a waste of effort, money and rope... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: tback]
#105277 04/30/07 12:31 AM 04/30/07 12:31 AM |
Posts: 120 Finland | Robi,
He said bolt ROPE! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Rope or line are both wrong, correct term would be "köysi" <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />. -- Valtteri | | | Re: Main halyard Stealth F16 trouble
[Re: Buccaneer]
#105278 04/30/07 02:05 AM 04/30/07 02:05 AM |
Posts: 3,528 Looking for a Job, I got credi... | Why the need for the convoluted halyard? Seems to me like a waste of effort, money and rope... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> It's not; It goes up the track in the mast, round a block at the top of the mast and then to the headboard of the sail.
[Re: scooby_simon]
#105279 04/30/07 03:47 AM 04/30/07 03:47 AM |
Posts: 1,479 Thailand | I see it as an additional and totally unnecessary failure point and a total waste of effort, where effort is not needed. Otherwise it’s OK… <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Buccaneer]
#105280 04/30/07 01:54 PM 04/30/07 01:54 PM |
Posts: 3,528 Looking for a Job, I got credi... | I see it as an additional and totally unnecessary failure point and a total waste of effort, where effort is not needed. Otherwise it’s OK… <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> [censored] ? please explain
[Re: scooby_simon]
#105281 04/30/07 08:56 PM 04/30/07 08:56 PM |
Posts: 1,479 Thailand | The halyard assemble is not necessary and adds another layer of convolution, so from a minimalist perspective it should not be there. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Buccaneer]
#105282 05/01/07 01:50 AM 05/01/07 01:50 AM |
Posts: 3,528 Looking for a Job, I got credi... | The halyard assemble is not necessary and adds another layer of convolution, so from a minimalist perspective it should not be there. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> But it is quicker than having to tip the boat over !
[Re: scooby_simon]
#105283 05/01/07 05:04 AM 05/01/07 05:04 AM |
Posts: 1,479 Thailand | Yes I guess so.. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
But is that your only alternative? Though it’s quite easy I’ve never needed to lay my Taipan on its side to raise the mainsail. In fact it’s faster then using the convoluted halyard set up. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Buccaneer]
#105284 05/01/07 05:41 AM 05/01/07 05:41 AM |
I use a mainsail halyard because the sailmaker who made my sail used a normal bolt rope and you can't push that up the mast. Push up sails require a flexible plastic tube to used as bolt rope.
So for me and some other sailors it is not a question of choice but necessity.
[Re: Wouter]
#105285 05/01/07 09:20 PM 05/01/07 09:20 PM |
Posts: 1,479 Thailand | Sad but true... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
The halyard is to compensate for the sail manufacturers error. It’s a temporary solution to a bigger issue. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
1 registered members (oldspice),
308
guests, and 39
