I-20 Mast leak #1285
07/31/01 02:18 PM
07/31/01 02:18 PM
Clermont, FL, USA
David Ingram Offline OP
Clermont, FL, USA
I suspect that the top of my mast is not sealed properly. I store my mast with the sail track facing up. There is a small amount of water that collects inside the mast after it rains. My questions are:
<br>
<br>After I get the mast cap off what is the best method to seal the top of the mast?
<br>Are there any known issues with removing the mast cap?
<br>
<br>David Ingram
<br>I-20<br><br>
1242- (16 downloads)
F18 USA 242
http://www.solarwind.solar
Re: I-20 Mast leak [Re: David Ingram] #1286
07/31/01 02:31 PM
07/31/01 02:31 PM
Chelmsford, MA
Barry Offline
Barry  Offline
Chelmsford, MA
Dave
<br>I had the same problem. I just poped off the mast cap. There are two water barriers inside. I cut out the upper one with a knife to get at the lower one. Once I had the lower barrier in sight I put on the gloves and slaped on the 5200. I put the upper barrier back and 5200 that. I haven't had a problem since. <br><br>
1246- (18 downloads)
Thanks! [Re: Barry] #1287
07/31/01 02:33 PM
07/31/01 02:33 PM
Clermont, FL, USA
Clermont, FL, USA
Thanks Barry, that is exactly what I needed to know.
<br>
<br>Dave<br><br>
1247- (17 downloads)
F18 USA 242
Re: I-20 Mast leak [Re: David Ingram] #1288
07/31/01 03:05 PM
07/31/01 03:05 PM
Mark Meis Offline
Mark Meis  Offline
Have you done a leak test to identify the problem spot.
<br>
<br>What I did was drill out a mast base rivit.
<br>
<br>Wash and soaped up my mast real good.
<br>
<br>Then blew air into the mast with a shop vac.
<br>
<br>While air is being blown in continue drenching all the potential points with a soapy spoonge. Any bubbles need attention.
<br>
<br>What I found was my mast was leaking at the diamond wire tang through bolt at the top of the mast. Apply silicone then immediately tighten the diamond wires. <br><br>Mark
<br>Inter 20 no. 274
<br>Houston, TX
1249- (18 downloads)
Mark C28R no. 140 Houston, TX
0 registered members (), 314 guests, and 40 spiders.
