| Standing Rigging Questions #173891 04/05/09 10:38 AM 04/05/09 10:38 AM |
Posts: 118 Pensacola, FL | I inspected my rigging yesterday and found 2 broken wires on each of the side stays. The broken wires are right next to each other and are where the wire goes into the swage sleeve above the thimble. The stays are 1/8 inch/3mm 1X19 wire. I am going to get new rigging but I have a few questions.
1. Are the stays safe to use until I get new ones? 2. The stays are simple, just thimbles at both ends. Can I go to West Marine and make my own? 3. What is the difference in the different wires, 1X19, 7X19, dyeform, PBO/easyrigging? Thanks in advance for the replies.
Chris Trident F16
| | | Re: Standing Rigging Questions
[Re: Cab]
#173895 04/05/09 11:10 AM 04/05/09 11:10 AM |
Posts: 3,293 Long Beach, California | 1. No. Don't ask me how I know. 2. If you're racing, check your class rules. Some classes have limits on size and type of standing rigging. If you're not racing, feel free to make your own. 3. Basically price and durability. If you're a recreational boater, I'd recommend the same size you already had and stainless.
[Re: Cab]
#173897 04/05/09 11:26 AM 04/05/09 11:26 AM |
Posts: 1,884 Detroit, MI | 1. No. Ask John how he knows. 2. Theoretically, yes. However, it's harder to do right than you think. Leave it to the guys who do it day in and day out. 3. 1x19 cable is one bundle of 19 wires. Strong and somewhat stiff. This is what wire standing rigging on beach cats is typically made from. 7x19 cable is 7 bundles of 19 wires each. It's much more flexible than 1x19, but not quite as strong. Trapeze wires and wire halyards / outhauls are made with this, but otherwise, it has few uses on beach cats. Dyform wire is made from non-circular wires that pack closer together, thus giving more strength and less stretch than traditional wire cable at the same diameter. It's overkill for a beach catamaran. ![[Linked Image]](http://www.performancerigging.co.uk/uploads/Image/dyform.jpg) PBO Zylon® (Poly(p-phenylene-2,6-benzobisoxazole))is a high performance fiber. PBO fiber has superior tensile strength and modulus to Aramid fibers (such as Kevlar, Technora and Twaron). PBO fiber shows excellent performance, in such properties as creep, chemical resistance, cut/abrasion resistance, and high temperature abrasion resistance, which far exceed Aramid fibers. PBO fiber is quite flexible and has very soft hand in spite of its extremely high mechanical properties. A very expensive material, PBO offer high performance and light weight at a premium price. Again, overkill for a typical beach catamaran. | | | Re: Standing Rigging Questions
[Re: Cab]
#173899 04/05/09 11:40 AM 04/05/09 11:40 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | 1. Are the stays safe to use until I get new ones? 2. The stays are simple, just thimbles at both ends. Can I go to West Marine and make my own? 3. What is the difference in the different wires, 1X19, 7X19, dyeform, PBO/easyrigging? Thanks in advance for the replies.
1) Nope. It's a big chance you take if you use it. A rig coming down potentially breaks a lot of other stuff. 2) Don't build your own. Just get it done right. I have a couple of boats a year that come in with failed Box Marine made rigging. Not to mention. I priced out Hobie 16 shrouds both from the factory and made at big box. The factory ones are $35 and the made ones, just in parts, came to around $60. The factory ones are right. Call your local rigger, give them the length and wire size and have them go to it. 3) What those guys said. J | | | Re: Standing Rigging Questions
[Re: F-18 5150]
#173904 04/05/09 02:02 PM 04/05/09 02:02 PM |
Posts: 749 Santa Cruz, CA | BTW... If you go with Dyform, Navtec hasn't been stocking it for a while. I know that Buzz at Ballenger Spars in Watsonville has several spools of various sizes of Dyform. Call him up if you go with Dyform. He makes rigs for all sorts of boats including Aclass, 5O5's, whatever. Good family owned shop, top quality, good to deal with. http://www.ballengerspars.com/ | | | Re: Standing Rigging Questions
[Re: F-18 5150]
#173905 04/05/09 02:09 PM 04/05/09 02:09 PM |
Posts: 3,906 Clermont, FL, USA | I live by the 2 year rule also.
[Re: F-18 5150]
#174012 04/06/09 04:11 PM 04/06/09 04:11 PM |
Posts: 3,969 | I tried being cheap ONCE. Made my own at WM, using their parts and tools. Failed the first day on the water. Thankfully, it was "just" the trapeze wires, not the stays. Really upset the crew when she went for a swim though. I still can't believe that she held onto the boat for that long...  Mike | | | Re: Standing Rigging Questions
[Re: JJ_]
#174019 04/06/09 04:42 PM 04/06/09 04:42 PM | andrewscott
| andrewscott
Unregistered | One brief addition. Don't throw away your old wires, keep them for reference! -- taking into account that they may have some stretch. They have no other practical value of course.
I beg to differ: First, and by far the most important use for broken stays.... They are PERFECT for dousing (and raising) the turkey from the fryer when ready 2nd.. i stretch an old one from my livingroom area into my dining room area ... to hang and dry my main and or spinnaker after a bath! | | | Re: Standing Rigging Questions
[Re: ]
#174022 04/06/09 04:54 PM 04/06/09 04:54 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | 2nd.. i stretch an old one from my livingroom area into my dining room area ... to hang and dry my main and or spinnaker after a bath! Your DINING ROOM? You must not be married... | | | Re: Standing Rigging Questions
[Re: HMurphey]
#174025 04/06/09 05:39 PM 04/06/09 05:39 PM |
Posts: 1,200 Vancouver, BC |
Dyform is a "high Tech" wire rope .... in normal wire rope all the strands a circular and therefore leave little spaces in between the strands when wound. In Dyform the strands are triangular (actually trapizodal) so that when wound together the strands are much tighter. Also the process of forming the strands into a trapizodal shape "work hardens"/strenghtens the strands resulting in stronger wire rope for the same size diameter .... some people like Dyform as you can reduce the diameter but still have the same strength.
I used dyform when I replaced the diamond wires on my P19 mast when I installed a chute but I used the same diameter since I was looking for more strenght for the increased loading.
I have been using Dyfrom on my Tornado for many years now...will never go back to 19 strand. To make Dyform, they wrap normal strands together then force the bundle through a dye (hence "Dyform")...this squashes the strands into the trapezoid shapes and removed most of the air spaces between them. The work hardening typically increases the strength by 1/3. The reduction in surface area helps slow down corrosion issues. The individual strands are larger than typical wire rope, thus they outlast others before needing replacement. I've never seen a bit of Dyform with a broken strand. I do replace it and have fall back sets just in case...but I'm getting way better life than with the older type. Mike.
[Re: Tornado]
#174029 04/06/09 06:16 PM 04/06/09 06:16 PM |
Posts: 3,528 Looking for a Job, I got credi... | [quote=HMurphey]
Mike. I have; we broke one sailing last year on a Tornado; went with a HELL of a ping. Went back to shore feckin quick I can tell you!!!!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Standing Rigging Questions
[Re: HMurphey]
#174038 04/06/09 06:52 PM 04/06/09 06:52 PM | andrewscott
| andrewscott
Unregistered | Andrew I hope you are not using "covered" wire for that turkey ... Hahahaha Harry No worries.. it melts right off .... and mmmm mmmmm good! | | | Re: Standing Rigging Questions
[Re: ThunderMuffin]
#174039 04/06/09 06:55 PM 04/06/09 06:55 PM | andrewscott
| andrewscott
Unregistered | 2nd.. i stretch an old one from my livingroom area into my dining room area ... to hang and dry my main and or spinnaker after a bath! Your DINING ROOM? You must not be married... Your wife doesn't love to see a spinnaker from room to room dripping on everything? My mail order bride came with a money back guarantee! (yes, not married) | | |
360
guests, and 36
