| Re: Hi new here - lots of questions
[Re: Ron in MI]
#182914 06/24/09 07:41 PM 06/24/09 07:41 PM |
Posts: 164 fort Myers, FL | Hi there, and welcome! Check out this forum on the Hobiecat listserve, it has answers to lots of questions: Hobie FAQ
Arie Hobie 16 111812
[Re: mmiller]
#183349 06/28/09 11:02 AM 06/28/09 11:02 AM |
Posts: 321 Albuquerque NM | The main traveler car will not move very well if you hare sheeted in on the main blocks. The more you sheet in, the harder it will be to move the traveler.
[b] Sail Like you have a Pair
[Re: Ron in MI]
#186097 07/24/09 04:04 PM 07/24/09 04:04 PM |
Posts: 160 North Carolina | I personally let out the main sheet first. Then ever so slightly head up into the wind
James 1983 Hobie 16'
[Re: abbman]
#186115 07/24/09 07:26 PM 07/24/09 07:26 PM |
Posts: 117 Atlanta, GA | Letting out the traveler lets the line out faster, there is a 1:1 ratio. If you have an 6:1 on your main sheet then letting out 6 feet of line lets out the boom out 1 foot. So releasing the traveler gives a more rapid release of the boom.
Kent 1988 H16
[Re: KentHobie]
#186116 07/24/09 08:41 PM 07/24/09 08:41 PM |
Posts: 5,582 “an island in the Pacifi... | Letting out the traveler lets the line out faster, there is a 1:1 ratio. If you have an 6:1 on your main sheet then letting out 6 feet of line lets out the boom out 1 foot. So releasing the traveler gives a more rapid release of the boom. True, but it's a gross vs. fine move. Plus, ya gotta haul it back in at 1:1 and those H16 travelers have never been very smooth. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Hi new here - lots of questions
[Re: hobie1616]
#186224 07/26/09 08:01 PM 07/26/09 08:01 PM |
Posts: 117 Atlanta, GA | I thought he was talking about dumping the boom fast to avoid a capsize. Most of my control is done with the main sheet. It seems to fly out even at 6:1 in a big gust. I guess thats because I have the main sheet in hand for control already.
Kent 1988 H16
[Re: hobie1616]
#186303 07/27/09 10:19 PM 07/27/09 10:19 PM |
Posts: 117 Atlanta, GA | Many people have one line that they use in a loop to control the blocks and the traveler. Some people use two different lines (possibly of different colors) and then tie them together so that they form a loop. This seems to reduce the confusion of which line to pull when.
In Rick White's book "Catamaran Sailing For The 90's" he says that the traveler is used to control the lower part of the main sail tension and that the main sheet is used to control the upper part of the sail. I think that this means that the main sheet tightens the boom downward which flattens the sail and pulls the main tighter higher up the sail, thus flattening the top part of the sail. Is this the right idea?
Kent 1988 H16
[Re: Ron in MI]
#186304 07/27/09 10:25 PM 07/27/09 10:25 PM |
Posts: 117 Atlanta, GA | Assuming the block (down haul?) tension needs to be released first to allow the car to even move. I think that Downhaul is the line that pulls the boom down at the mast. This tightens the luff of the mainsail. I think that my boat has a 6:1 for the downhaul.
Kent 1988 H16
414
guests, and 195
