Hi new here - lots of questions #182911
06/24/09 07:16 PM
06/24/09 07:16 PM
Grand Rapids, MI
Ron in MI Offline OP
Grand Rapids, MI
Hi - I just picked up a heavily used 16. I mean heavily used... 4 hours of power washing and it's not that bad.
(Paid only 450.00!) with trailer.
anyway - I didn't know about soft spot checking until after I bought it. It has a BAD soft spot just forward of the tramp on the port side. (any good way to fix that?) Feels like someone could put their foot through it. And has a stress crack already.
That's first question. Next is - what is the best way to learn how to rig properly? I have some problems.
First I THINK the main sheet is to big... the rope is fat and from wear is a bit frayed and doesn't move smoothly or easily through the cleat/pulleys? Should it be snug or easily slip through the block and tackle stuff? I suspect a thinner rope is needed? what type/rope should I get and where? (best place to buy)?
Other things the SLIDING unit on the aft tramp bar that slides port and starboard gets hung up in the track frequently. We have to fight with it to get it to release and slide smoothly. (is there a fix for this? or just I order a new part?) How should this release and lock?
Those are just my starter questions. Even rigged wrong and with problems I've had a blast sailing it the last 2 days with little to no wind. Can't wait for something more substantial.
Re: Hi new here - lots of questions [Re: Ron in MI] #182914
06/24/09 07:41 PM
06/24/09 07:41 PM
fort Myers, FL
arievd Offline
arievd  Offline
fort Myers, FL
Hi there, and welcome!
Check out this forum on the Hobiecat listserve, it has answers to lots of questions:
Hobie FAQ
Arie
Hobie 16 111812
Re: Hi new here - lots of questions [Re: arievd] #182916
06/24/09 07:58 PM
06/24/09 07:58 PM
Grand Rapids, MI
Grand Rapids, MI
thanks - registered there, but it's a FUNKY forum and needs someone to turn me on (rather than email confirmation).
= ( Been waiting, havent' heard back from anyone there.
Re: Hi new here - lots of questions [Re: Ron in MI] #183063
06/25/09 01:54 PM
06/25/09 01:54 PM
California
mmiller Offline
mmiller  Offline
California
Yeah, we had a bunch of spam and porn issues... clean now due to the manual registration process, but that does take a bit of time. Did you email us per the "New users" post in the forums?
http://www.hobiecat.com/community/viewtopic.php?f=57&t=12747
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hi new here - lots of questions [Re: mmiller] #183349
06/28/09 11:02 AM
06/28/09 11:02 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
The main traveler car will not move very well if you hare sheeted in on the main blocks. The more you sheet in, the harder it will be to move the traveler.
[b] Sail Like you have a Pair
Re: Hi new here - lots of questions [Re: Banzilla] #186094
07/24/09 04:00 PM
07/24/09 04:00 PM
Grand Rapids, MI
Grand Rapids, MI
Bought a 2nd boat which was setup properly - found that the main sheet wasn't going through car properly. I had one rope end in my hand. (couldn't control the traveler car seperate. 2nd boat I bought was set right and I went AH HA... I now have a loop in my hands (end is tied to back center of aft support behind traveler car. WOW much easier to work both controls now.
IN A BIG GUST - what would one want to release first? the down haul cleat on the main shoot or the traveler car cleat? Before - I just had one and popped the cleat to not go over.
Re: Hi new here - lots of questions [Re: Ron in MI] #186097
07/24/09 04:04 PM
07/24/09 04:04 PM
North Carolina
abbman Offline
abbman  Offline
North Carolina
I personally let out the main sheet first. Then ever so slightly head up into the wind
James
1983 Hobie 16'
Re: Hi new here - lots of questions [Re: abbman] #186115
07/24/09 07:26 PM
07/24/09 07:26 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
Letting out the traveler lets the line out faster, there is a 1:1 ratio. If you have an 6:1 on your main sheet then letting out 6 feet of line lets out the boom out 1 foot. So releasing the traveler gives a more rapid release of the boom.
Kent
1988 H16
Re: Hi new here - lots of questions [Re: KentHobie] #186116
07/24/09 08:41 PM
07/24/09 08:41 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
True, but it's a gross vs. fine move. Plus, ya gotta haul it back in at 1:1 and those H16 travelers have never been very smooth.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hi new here - lots of questions [Re: hobie1616] #186224
07/26/09 08:01 PM
07/26/09 08:01 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
I thought he was talking about dumping the boom fast to avoid a capsize. Most of my control is done with the main sheet. It seems to fly out even at 6:1 in a big gust. I guess thats because I have the main sheet in hand for control already.
Kent
1988 H16
Re: Hi new here - lots of questions [Re: KentHobie] #186254
07/27/09 09:16 AM
07/27/09 09:16 AM
Grand Rapids, MI
Grand Rapids, MI
Now that I'm rigged properly, I have two lines (one to block and one to traveler. Is this then two sheets?
Which to release to stop a capsize? I've tried to do both - a down on the block and then a up on the traveler. Assuming the block (down haul?) tension needs to be released first to allow the car to even move.
Re: Hi new here - lots of questions [Re: Ron in MI] #186257
07/27/09 10:28 AM
07/27/09 10:28 AM
hobie1616 Offline
hobie1616  Offline
Release the main only. It'll take forever to pull both back in.
Re: Hi new here - lots of questions [Re: hobie1616] #186303
07/27/09 10:19 PM
07/27/09 10:19 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
Many people have one line that they use in a loop to control the blocks and the traveler. Some people use two different lines (possibly of different colors) and then tie them together so that they form a loop. This seems to reduce the confusion of which line to pull when.
In Rick White's book "Catamaran Sailing For The 90's" he says that the traveler is used to control the lower part of the main sail tension and that the main sheet is used to control the upper part of the sail. I think that this means that the main sheet tightens the boom downward which flattens the sail and pulls the main tighter higher up the sail, thus flattening the top part of the sail. Is this the right idea?
Kent
1988 H16
Re: Hi new here - lots of questions [Re: Ron in MI] #186304
07/27/09 10:25 PM
07/27/09 10:25 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
I think that Downhaul is the line that pulls the boom down at the mast. This tightens the luff of the mainsail. I think that my boat has a 6:1 for the downhaul.
Kent
1988 H16
0 registered members (), 1,948 guests, and 34 spiders.
