Traveller sheet #222453
10/24/10 07:44 PM
10/24/10 07:44 PM
Scarecrow
Scarecrow
Has anyone come up with a successful way to move the traveller cleat forward to allow mid tramp traveller sheeting along with the main sheet?
Re: Traveller sheet [Re: ] #222752
10/26/10 08:40 PM
10/26/10 08:40 PM
fmg Offline
fmg  Offline
I've seen some pics of paper tigers with a pretty neat traveller setup that runs through the centre beam to a cleat near the mainsheet, looked pretty simple to do. Basicall uses a small harken or ronstan flip-flop block mounted on a carbon or alloy platform mounted on the back side of the beam, then I think there was a small alloy tube glued or welded through the back beam for the line to run through into the centre beam, pretty simple from there. Basically the traveller line runs backwards to the flip-flop block, through the centre beam then forwards to a cleat platform.
Might make a little too much clutter on a mozzie though, especially if you are running the kite gear to the centre beam.
Re: Traveller sheet [Re: fmg] #222762
10/26/10 10:24 PM
10/26/10 10:24 PM
Scarecrow
Scarecrow
I've seen similar but can't find the photos. From memory it was Chris Haywood's boat.
0 registered members (), 794 guests, and 26 spiders.
