F16 Purchase Decision Guidence Needed #234318
07/04/11 11:02 AM
07/04/11 11:02 AM
C
CleanLivin Offline OP
C
Greetings,
I'm an ole cat sailor for the 60's and 70's. Had the Hobie 14, 16, 18 back then and sailed off Galveston Island. Vast majority was solo and I loved it.
Now I'm nearing 65, 6'4" and 205#'s and want to get back into cat sailing.
Have done some research in the attempt to get up to speed on what has changed in the last 3 decades - WOW!
I'm concluding that at my age and the propensity to solo sail with the need to have a boat that can take my wife or a buddy on occasion, the F16 class is what I should go with.
It seems the ideal solo or two up rig - put out sails as I need them relative to crew.
I will be primarily day sailing and see very little potential to compete, but it would be nice to have that as a remote option.
Thus, I setting out on the pilgrimage to find the best USED F16 to meet my needs yet trying to keep the budget in the less than $12,000 bracket with trailer, less than $10K is even better and at or under $7K is ideal.
That said, I'd sincerely appreciate your guidance as to what brands/models of F16's I should seek out and where are the best places to find them. I interested in what companies have solid reputations for producing excellent F16's.
Ideal cat will be relatively solid/not unduly fragile requiring constant maintenance and expense. It does not have to be the latest generation, a couple iterations back is fine.
Looking forward to your guidance.
Jack
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234320
07/04/11 12:07 PM
07/04/11 12:07 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Look on the Catsailor Classified ads. There are 2 used boats listed. One looks to be real local to you. Tiki Pete owns the same brand boat as the one in Orlando. I'm sure he will be here shortly.
Re: F16 Purchase Decision Guidence Needed [Re: jkkartz1] #234334
07/04/11 03:58 PM
07/04/11 03:58 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Check with Matt McDonald at Falcon Marine (http://www.falconmarinellc.com). He is very close to you and will know of available second hand boats.
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234371
07/05/11 09:57 AM
07/05/11 09:57 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
If you aren't racing then you could look at a Nacra 500. Much simpler than an F16 and a lot less money. For that money you could buy a new one. 500 pic
Very similar size to F16. You can sail 1 person or 2. You can right it with 1 person. Optional spin.
Re: F16 Purchase Decision Guidence Needed [Re: pitchpoledave] #234381
07/05/11 10:29 AM
07/05/11 10:29 AM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Nothing against the 5.0, if you have a very tight budget and your only requirement is having a 16 foot boat.
Sailing a true F16 is a completely different experience.
Re: F16 Purchase Decision Guidence Needed [Re: Matt M] #234389
07/05/11 11:12 AM
07/05/11 11:12 AM
Toronto, Ontario
Toronto, Ontario
Matt the F16 is more of a high performance boat no doubt but at greatly added complexity and cost.
Re: F16 Purchase Decision Guidence Needed [Re: pitchpoledave] #234397
07/05/11 01:55 PM
07/05/11 01:55 PM
The 500 is also a great deal heavier Dave.
Around 150Kg+ versus the F16 at 104Kg/107Kg up to a real heavyweight at 130Kg
Re: F16 Purchase Decision Guidence Needed [Re: Jalani] #234406
07/05/11 02:57 PM
07/05/11 02:57 PM
France
pepin Offline
pepin  Offline
France
The 500 is a very good boat, easy to handle. Simple rigging, no daggerboard, just skegs. This makes for a very streamlined boat with simple controls.
A F16 will be faster, will go upwind better, and will be way way way lighter. If you race you want a F16.
I'm sceptical with the ability to right a nacra 500 alone unaided in all conditions however. I think a righting pole might be necessary.
Re: F16 Purchase Decision Guidence Needed [Re: pepin] #234407
07/05/11 03:02 PM
07/05/11 03:02 PM
Toronto, Ontario
Toronto, Ontario
yes it is heavier, 300lbs vs 240lbs for the Blade or 285lbs for the Viper.
One person of 160lbs can definitely right the Nacra 500. We have tested it. The mast is quite light.
Re: F16 Purchase Decision Guidence Needed [Re: pitchpoledave] #234423
07/05/11 04:41 PM
07/05/11 04:41 PM
FL
sail7seas Offline
sail7seas  Offline
FL
Re: F16 Purchase Decision Guidence Needed [Re: sail7seas] #234433
07/05/11 07:40 PM
07/05/11 07:40 PM
C
C
F16 is what I'm really after due to weight and my being a solo sailor a majority of the time. As mentioned in my original post, I'm bumping up against 65 and still have my back in good condition. Wrestling a Hobie 16 or the like up the beach is not going to lengthen the life of my back compared to an F16.
Besides the weight advantage of an F16, I like the versatility it gives me for one up verse two up sailors. I can see myself sailing it much of the time with just the main and a spin. Add the jib when I have a crew member aboard.
So what brands/models/years of F16 used should I be searching for?
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234435
07/05/11 09:47 PM
07/05/11 09:47 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
Agreed: your back will thank you for getting a lighter boat.
I own a 2006 VectorWorks Blade F-16. You could certainly pick one of these up within your price range. These are solid boats. But be aware that the older F-16s like this are very demanding downwind. The newer designs like the Falcon and Viper might be easier to keep upright, but probably not within the budget.
If you mostly sail solo and want something light and cheap and within the budget, consider an old A-cat like a 2000ish Boyer Mk 4. Your back will love you. And you won't miss the spinnaker.
-Geoff
Re: F16 Purchase Decision Guidence Needed [Re: GeoffS] #234438
07/06/11 04:18 AM
07/06/11 04:18 AM
pgp Offline
pgp  Offline
Jack, I forgot to mention the Taipan 4.9. It actually predates the F16 class and was grandfathered into the class. When we weighed boats for the Nationals, we found they were the lightest. There were a couple at Gulfport, you'd have to check with the folks up there. One was damaged in a collision and was repaired the other is original as far as I know.
There are only four models of F16 I'm aware of: Blade, Falcon,Taipan 4.9 and Viper.
Pete Pollard
Blade 702
Re: F16 Purchase Decision Guidence Needed [Re: pgp] #234439
07/06/11 04:42 AM
07/06/11 04:42 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I have to agree with the Taipan 4.9, heres a link to my favorite video of a 4.9 in plenty of wind taking on 2 x Blades,F18 Infusion, Wildcat, Taipan 5.7's plus others all of these you'll see in the background
http://www.youtube.com/watch?v=-LzOSWfIZzI
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: F16 Purchase Decision Guidence Needed [Re: pgp] #234447
07/06/11 09:07 AM
07/06/11 09:07 AM
Aussie Blade, Stealth, Razor, Aquaraptor, G-cat F16.
New additions TBC: Bimare F16, Duma F16, Nacra F16
Then of course there are the homebuilds.......
Re: F16 Purchase Decision Guidence Needed [Re: Jalani] #234450
07/06/11 10:02 AM
07/06/11 10:02 AM
Yeah, but I think Pete as getting at what's in the US, there's a couple of Stealth's, 1 G-cat, and the NACRA only exists on paper. The others I don't think are here at all.
Re: F16 Purchase Decision Guidence Needed [Re: Karl_Brogger] #234562
07/08/11 09:44 AM
07/08/11 09:44 AM
C
C
Looks like the Viper is coming up to the top of my list.
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234565
07/08/11 10:06 AM
07/08/11 10:06 AM
pgp Offline
pgp  Offline
"...I do not see myself racing it."
Yeh, yeh, yeh. We've heard that before.
Pete Pollard
Blade 702
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234588
07/08/11 10:22 PM
07/08/11 10:22 PM
Where are you located?
Nevermind........ Naples.
I know Red Gear Racing has at least one used Viper available.
Re: F16 Purchase Decision Guidence Needed [Re: CleanLivin] #234602
07/09/11 08:37 PM
07/09/11 08:37 PM
Long Island, NY
gregP19 Offline
gregP19  Offline
Long Island, NY
If you've got a den with some empty space to fill on the mantle, a Nacra 500 might be a good deal. With a rating close to a H16 you might bring home some trophies without a lot of effort!I've always thought that the 5.0 (500) was a lot faster than its' rating.
1 registered members (FredL), 505 guests, and 97 spiders.
