| I should make sure not to leave my helmet on the short bus.. #242656 01/19/12 03:08 PM 01/19/12 03:08 PM |
Joined: Feb 2005 Posts: 4,119 Northfield Mn Karl_Brogger OP
Posts: 4,119 Northfield Mn | I learned something new at Tradewinds, or at least while I was sailing around a few days before.
I have trouble consistently righting the boat singlehanded with just a line. So after drifting for 15 minutes, and about to give up and call the coach boat over I gave it another shot. Wrapped the line around my hook, leaned out, and threw one ARM over my head, and it came up. I could get the mast out of water before, but not past horizontal.
eYe feall dumbie.....
| | | Re: I should make sure not to leave my helmet on the short bus..
[Re: Karl_Brogger]
#242660 01/19/12 03:51 PM 01/19/12 03:51 PM |
Posts: 5,525 | Um, that's gotta be orientation to the wind. Sometimes the boat will swing under me almost 45 degrees before it comes up, then it almost rights itself.
btw- did you notice the round the horn guy was on the down hull and just rode it up, kept the boat from going all the way over.
Pete Pollard Blade 702
[Re: Karl_Brogger]
#242665 01/19/12 04:33 PM 01/19/12 04:33 PM |
Posts: 5,525 | That was my point! Even with my weight the boat has to swing round to the correct orientation or it will just sit there.
If the air is light enough I might have to walk forward or backward on the hull to get it to pivot.
It's hard for me to believe the weight of one arm was sufficient to make the difference for you to right solo. Some of the lighter guys carry empty trash bags to scoop up enough water to right the boat.
[Re: Karl_Brogger]
#242699 01/20/12 10:25 AM 01/20/12 10:25 AM |
Posts: 4,119 Northfield Mn | I was oriented well, just couldnt get her to go. Threw my arm up and when it started to come up, all I could think was "you gotta be shittin' me"
[Re: Karl_Brogger]
#242701 01/20/12 10:47 AM 01/20/12 10:47 AM |
Posts: 6,049 Sebring, Florida. | It might have also been a good gust of wind getting under the mast, or a good wave, helping to right it. I righted my Inter 20 by myself several times, but it was really the wind getting under the mast that flipped it up...and sometimes right over the other way!
Blade F16 #777
[Re: Karl_Brogger]
#242732 01/20/12 01:34 PM 01/20/12 01:34 PM |
Posts: 4,119 Northfield Mn | and I had to be right on the edge. I capsized again, later that day and same results. Arm over the head, and up she came.
The good news is this saves me a bunch of money, I was thinking about putting a carbon mast on to make righting a squeak easier.
[Re: Karl_Brogger]
#242738 01/20/12 02:59 PM 01/20/12 02:59 PM | MarkMT
| MarkMT
Unregistered | Were you using the under-tramp line or over the hull? (just curious - I realize it makes no difference to the righting moment.) | | | Re: I should make sure not to leave my helmet on the short bus..
[Re: Karl_Brogger]
#242739 01/20/12 03:21 PM 01/20/12 03:21 PM |
Posts: 6,049 Sebring, Florida. | Or...maybe you've got really, really, fat arms!
Blade F16 #777
[Re: Karl_Brogger]
#242766 01/21/12 04:05 AM 01/21/12 04:05 AM |
Posts: 1,382 Essex, UK | Perhaps you have a particularly heavy watch???
John Alani ___________ Stealth F16s GBR527 and GBR538 | | |
865
guests, and 29
