Hobie 16 Tatoo #234040
06/24/11 04:02 PM
06/24/11 04:02 PM
FL
sail7seas Offline OP
FL
Re: Hobie 16 Tatoo [Re: sail7seas] #234064
06/26/11 01:50 PM
06/26/11 01:50 PM
FL
FL
Re: Hobie 16 Tatoo [Re: sail7seas] #234071
06/27/11 02:12 AM
06/27/11 02:12 AM
japan
erice Offline
erice  Offline
japan
not bad
behind 2 h16s and a prindle16
but ahead of a heck of a alot of f18s!
http://rotserver.mondriaanict.nl/IIS/XmlTransformer?xml=http://rotserver.mondriaanict.nl/IIS/getTmp.jsp?file=IIS2011.xml&xsl=http://rotserver.mondriaanict.nl/IIS/finishlists/rot2011/openklasse.xsl
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Hobie 16 Tatoo [Re: erice] #238967
10/12/11 05:35 PM
10/12/11 05:35 PM
FL
FL
Re: Hobie 16 Tatoo [Re: sail7seas] #249092
06/02/12 09:33 AM
06/02/12 09:33 AM
Lincoln, Nebraska
FRENZIED Offline
FRENZIED  Offline
Lincoln, Nebraska
Resurrecting a thread...
I like the idea of the Tatoo. I think it could benefit from a little bit bigger main (especially with a weight of 170kg) and a boom. A better alternative to the H16? I bet it's at least more durable.
LANDLOCKED
Re: Hobie 16 Tatoo [Re: FRENZIED] #250765
07/13/12 09:04 AM
07/13/12 09:04 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Re: Hobie 16 Tatoo [Re: sail7seas] #261875
07/31/13 01:06 AM
07/31/13 01:06 AM
M
mmogoingjian Offline
M
I want to say press release is the best medium for promoting a new business or any news or products launched by a company or firm.It is a great medium of getting the traffic on a website.If i forget some points about press release please share your views.
_____________________________________________________
buy rs gold
buy cheap fifa gold
Re: Hobie 16 Tatoo [Re: sail7seas] #267723
12/13/13 04:29 PM
12/13/13 04:29 PM
Dunedin Causeway, FL
David Parker Offline
Hobie Europe's "Tatoo" is now the Hobie US "T2" (cute name morph). Note the spin pole.
They have them in the store in Tackle Shack in Pinellas Park near Tampa, FL.
Hobie T2
Hobie's T2 Forum
Re: Hobie 16 Tatoo [Re: David Parker] #267749
12/15/13 04:16 PM
12/15/13 04:16 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
It would be interesting to see some head to head competition between a T2 and one of Rick's heated up Waves.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hobie 16 Tatoo [Re: sail7seas] #267838
12/18/13 08:26 PM
12/18/13 08:26 PM
Or against a standard H16.
It says the T2 weighs 388 with 178 sq. ft. sail area, how does that compare to the H16?
Also, looks like single trap only? My guess is the H16 is going to be quicker upwind, but with the spinnaker the T2 would pass them downwind.
So...who's going to be the first to hot rod one and add a bigger, self tacking jib?
Here's the H16 specs. from the Hobie website:
Hobie 16
Complete Specs & Features
Specifications
Crew: 1-4
Length: 16' 7" / 5.04 m
Beam: 7' 11" / 2.41 m
Capacity: 800 lbs / 362 kg
Weight: 320 lbs / 145 kg
Draft w/ Rudder Up: 10" / .25 m
Mast Length: 26' 6" / 8.07 m
Total Sail Area: 218 sq ft / 20 sq m
From that it looks like the H16 is 68lbs. lighter and has 40sq.ft. more sail area, so it should be faster upwind.
Re: Hobie 16 Tatoo [Re: Timbo] #267884
12/19/13 05:58 PM
12/19/13 05:58 PM
Compare the Hobie Tatoo with the Nacra Playcat as discussed on the main Forum under "New Junior multihull - Playcat Mark 2". More photos there.
After some heavy R&D the new Playcat Mark2 is ready for the market.
Its an entry level boat for the jr sailing fleets and recreational/resort markets. Designed by Morelli and Melvin.
Rotomolded plastic. 320 lbs
More specs at www.nacra.ca
Starting at $5500 for the base boat with main only.
The base model has the original rudders.
The Sloop model is $7950 which includes a single trapeze, tiller extension and the new rudders.
The Sport model: add a spin kit for an additional $1700.
The next production run will be this winter with delivery early spring.
Re: Hobie 16 Tatoo (Hobie T2) [Re: David Parker] #268490
01/15/14 11:52 PM
01/15/14 11:52 PM
Issaquah, WA, USA
H17cat Offline
H17cat  Offline
Issaquah, WA, USA
Just saw a T2 being put together at Sail Sand Point in Seattle today by Hobie Cats Northwest, for the Seattle Boat show. Boat looks very good, should be fun to sail.
Caleb Tarleton,
Sail Sand Point
1 registered members (fixitsteve), 1,030 guests, and 40 spiders.
