Mast over-rotation question? #59371
10/18/05 10:02 AM
10/18/05 10:02 AM
Ontario, Canada
Captain_Dave Offline OP
Ontario, Canada
I have an older H16 and the stops on both the mast base and step are worn in a way that allows the mast to over-rotate by about 10 degrees.
Can someone tell me how significant this is? Will it change the boats performance? If so, in what way? Anybody have a fix for this besides replacement?
Dave
Re: Mast over-rotation question? [Re: Captain_Dave] #59372
10/18/05 02:34 PM
10/18/05 02:34 PM
California
mmiller Offline
mmiller  Offline
California
Over rotation will flatten the sails upwind. This can be good in higher wind, but less power is a performance loss most times.
You can cut away a little more of the stop, drill, tap and insert a stainless bolt. Cut it flush and grind flat as a stop. Cheater than replacements, but a lot more work.
The new steps and bases work really well and wear less. well worth the cost.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Mast over-rotation question? [Re: mmiller] #59373
10/18/05 02:55 PM
10/18/05 02:55 PM
Ontario, Canada
Ontario, Canada
Thanks Matt.
Dave
Re: Mast over-rotation question? [Re: Captain_Dave] #59374
10/19/05 01:00 AM
10/19/05 01:00 AM
Minnesota
Jeff Peterson Offline
Minnesota
Why not have your local aluminum welder build back the worn aluminum ?
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Mast over-rotation question? [Re: Jeff Peterson] #59375
10/19/05 09:26 AM
10/19/05 09:26 AM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Welding on the aluminum castings can invite trouble down the road. It changes the properties of the metal near the weld due to the high heat.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
0 registered members (), 703 guests, and 35 spiders.
