| Re: Jammed rudder pins
[Re: HangOver]
#73746 04/29/06 12:57 PM 04/29/06 12:57 PM | Anonymous
| Anonymous
Unregistered | Andy: You might try some CLR. I got a zipper loose with it. Doug Snell Hobie 17 Sunfish Soon to be Mystere 4.3 www.tcdyc.com | | | Re: Jammed rudder pins
[Re: HangOver]
#73751 04/29/06 04:48 PM 04/29/06 04:48 PM |
Posts: 12,310 South Carolina | What kind of boat? (it might help to understand what the pin and casting look like).
Jake Kohl | | | Re: Jammed rudder pins
#73752 04/29/06 06:43 PM 04/29/06 06:43 PM | Anonymous
| Anonymous
Unregistered | Had a zipper that was corroded REAL bad to the metal slide. Soaked it overnight and it cam loose. Try CLR (Calcium, Lime and Rust) if you can find it.
Doug | | | Re: Jammed rudder pins
[Re: HangOver]
#73754 04/30/06 01:52 PM 04/30/06 01:52 PM |
Posts: 5,582 “an island in the Pacifi... | After soaking it in penetrating oil for a while you might tap on the pins with a punch from underneath.
If you can't break it loose it might be easier to remove the gudgeons from the boat and cut the pins. Repalce the gudgeons and pins and polish the holes in the rudder castings before assembly. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
300
guests, and 43
