Forward internal bulk heads have come loose #198900
12/12/09 08:53 PM
12/12/09 08:53 PM
Port Noarlunga South Aus
Red C Offline OP
Red C  Offline OP
Hi all, A mate has a fiberglass mossie and the ply bulkheads inside the hull under the forward cross beam have come loose. Has anyone encountered this and what do people recommend to remedy this. Cheers
Re: Forward internal bulk heads have come loose [Re: Red C] #199379
12/22/09 05:42 PM
12/22/09 05:42 PM
greymatter Offline
greymatter  Offline
if this boat is a fiberglass boat with timber frames and timber deck dont wast time or money on it this would be a blokey boat. recomend scaping the hulls and getting some good timber ones. if he still wonts to sail it could always get some 2" fiberglass tape and fiberglass the frame in. you should be able to have enough access through the hatch cover.
Re: Forward internal bulk heads have come loose [Re: greymatter] #199392
12/22/09 09:20 PM
12/22/09 09:20 PM
Red C Offline OP
Red C  Offline OP
no the boat is completely fiberglass, deck, hull etc, the bulkhead is just a support that is cut to the shape of the cross section of the hull that I presume gives support under the forward cross beam that supports the mast. i would imagine that this would be the most stressed part of the hull. Maybe members could let me know if this bulkhead is in place in their fiberglass boats or if the hull is purely empty?
Re: Forward internal bulk heads have come loose [Re: Red C] #201049
01/22/10 06:48 PM
01/22/10 06:48 PM
Parkdale, Vic
N
NixonJr Offline
NixonJr  Offline
N
Parkdale, Vic
I'v had the same problem happen to my cobra,
you will need to rip off the deck and fiberglass the frame back in. In my case i made a new frame because it had split!
Best way is to mix up some fiberglass bog and use a big ice-cream stick to smooth around between the hull and the frame. Then place some fiberglass tape to secure the frame.
Robert Nixon
Cobra 581 - Sweet Dreams
Stingray 582
Cobracat.com
Re: Forward internal bulk heads have come loose [Re: Red C] #201060
01/22/10 09:53 PM
01/22/10 09:53 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
Just noticed you are in Port Noarlunga South, I live there too so I can check out this bulkhead problem if you want. Send me a pm with your phone number.
Darryn
Mozzie
1782
Re: Forward internal bulk heads have come loose [Re: NixonJr] #201284
01/26/10 04:19 AM
01/26/10 04:19 AM
Peter_Foulsum Offline
Rick or Robert,
Welcome to the Mozzie forum/swarm. grin
Great to have a Cobra stalwart aboard. smile wink
Peter
Mosquito 1814
Macka Mozzie
Re: Forward internal bulk heads have come loose [Re: Peter_Foulsum] #201359
01/26/10 08:22 PM
01/26/10 08:22 PM
Parkdale, Vic
N
NixonJr Offline
NixonJr  Offline
N
Parkdale, Vic
arr someone knows my name smile
Thought i better come and mix it up a bit,
Rob smile
Robert Nixon
Stingray 582
Cobracat.com
Re: Forward internal bulk heads have come loose [Re: NixonJr] #201379
01/27/10 06:07 AM
01/27/10 06:07 AM
Hi Rob,
What was the cause of the problem ?
Since both the Cobra and the Mosquito are similar they would have the similar stresses in that area.
Would a stiffer bulkhead at initial build fix the problem or do you think that a stiffer hull doubler is better ? confused
I assume that there were no issues with the original attachment. Maybe that's just a wild assumption. crazy
Peter
Mosquito 1814
Macka Mozzie
Re: Forward internal bulk heads have come loose [Re: Peter_Foulsum] #201474
01/28/10 02:38 AM
01/28/10 02:38 AM
Parkdale, Vic
N
NixonJr Offline
NixonJr  Offline
N
Parkdale, Vic
umm not sure on cause,
as the frame was broken when i bought the boat,
I suspect that the hull had been hit by something as it looks like it has been repaired but they did not notice/fix the broken frame...
We simpley took the deck off pulled out the old frame and replaced it with 10mm foam sandwich fiberglass frame... however the old frame's had big air-flow holes in them - maybe this is why mine broke and came lose.
Robert Nixon
Stingray 582
Cobracat.com
Re: Forward internal bulk heads have come loose [Re: NixonJr] #201575
01/29/10 06:10 AM
01/29/10 06:10 AM
Rob,
Big airflow holes !! cry eek What were they thinking !!
I assume you used structural grade foam for the new frame.
Is it just a single frame or are there other stiffeners as well ? I have seen some Mozzies where they have some other frame type stiffening close to the front beams.
Peter
Mosquito 1814
Macka Mozzie
Re: Forward internal bulk heads have come loose [Re: Peter_Foulsum] #201631
01/30/10 12:50 AM
01/30/10 12:50 AM
Parkdale, Vic
N
NixonJr Offline
NixonJr  Offline
N
Parkdale, Vic
pete,
We used 10mm foam with a layer of 6oz cloth on each side. then cut it to the shape. Normally you use 4mm foam for hulls i think so yes its a very strong frame now... we also cut 2 50mm holes instead of 2 100mm air flow holes so it should be alot better.
We also placed 2 half frames below the front deck to stiffen it up alot smile
After all of the changes to both hulls the boat still came in under weight smile
Robert Nixon
Stingray 582
Cobracat.com
0 registered members (), 1,268 guests, and 34 spiders.
